Greece and Galia....spears...
From the longest: 45.5 cm, width 28 mm, hole 19 mm, weight 240 grams. 36.5 cm, width 31 mm, hole 16 mm, weight 190 grams 27 cm, width 38 mm, hole 16 mm, weight 140 grams 27.5 cm, width 25 mm, hole 17 mm, weight 130 grams 24.5 cm, width 32 mm, hole 17 mm, weight 130 grams
Those are so nice Ibor! Thanks for the pictures.
  • 1 month later...
Those came out great. How did you do the rib?
  • 4 months later...
... I have described it several times ... first in form then on the side of the anvil.
Half-faced blows, no? There's a video of Thijs Van de Manakker making a similar spearhead on youtube somewhere that shows the method.
