Fuzzyguy Posted December 22, 2018 Share Posted December 22, 2018 I have a small hand crank blower with a repaired 91-20 gear and need to know what oil? to use in the gear case. Any thoughts are appreciated. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 22, 2018 Share Posted December 22, 2018 I use either 80wt gear oil or chainsaw bar oil with a little STP in it. Only enough oil for the lower gear teeth to run in it to splash the oil to other gears & bushings. Too much oil will only leak out. What make blower? Quote Link to comment Share on other sites More sharing options...
Fuzzyguy Posted December 22, 2018 Author Share Posted December 22, 2018 Thanks, Now to heat some iron! Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted December 24, 2018 Share Posted December 24, 2018 Some don’t hold oil at all, those that have Oiler cups at the top don’t hold oil, and a few drops of bar oil, 90wt or 30wt non detergent. Quote Link to comment Share on other sites More sharing options...
frankauten Posted December 24, 2018 Share Posted December 24, 2018 go with what so others added////90 wt gear oil )rear end Walmart in auto section Less the five bucks again to old farts only an inch or so ...I did last week ,,,,Let us know how you are doing ,Also spend some extra $$ on apron that is over $40 any less and you are wasting dollars found top end are 100 and up.....but are really a dream to wear and easy to doff on and off....Eye protection I like full face head band ...as an emt ////remember an EYE injury is the most painfull youll endure ,,,,also if yo drop red hot iron on concrete ,,,,,,it will first turn any minute moisture into …...steam water freezes @32 liquid @ 40 and at 21 turns to steam ,,,,,,,,,,,expanding 1900 times it self In volume ,,,,,this lifts concrete /rock gravel and worse the cement needed to make the concrete...consisting of sand ,,,,not good on eye ball and lime OUCH !!!!! okay im off my soapbox ,however as a mechanic over the years ive seen chunks air bornd and a lot of big guys in tears ..also great protection for weed eating Work safe God bless Frank in Clover SC Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted December 24, 2018 Share Posted December 24, 2018 Because mine leaks it out as it is used I just pour some of my old motor oil into the case before using. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 24, 2018 Share Posted December 24, 2018 17 hours ago, frankauten said: Frank in Clover SC Welcome to IFI Frank... Have you read this yet? It will help you get the best out of the forum. READ THIS FIRST We won't remember your location after leaving this post, hence the suggestion to edit your profile to show it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 27, 2018 Share Posted December 27, 2018 I use the oilers they make for swampcooler's, nice spout, clean machine oil, just a squirt in through the top oil hole as needed. As mentioned some are flow through oil systems and would profit from the al roasting pan of kitty litter under them. Having a dirt floor in my shop---not a problem! Quote Link to comment Share on other sites More sharing options...
