looking for a leg vise
lumettamichel3
Keep in mind that you only absolutely need two things to do twists: something to hold one end firmly, and something to twist with. I have successfully held workpieces for twisting by clamping them to the side of my anvil with a big C-clamp. Even a hobbyist's bench vise will do fine, if clamped down firmly enough.
The big advantage of a post vise is that you can hammer on it. Anything else (bending, twisting, filing, etc) can be done in pretty much any vise of sufficient size.
