Jonathan Smidt Posted October 24, 2018 Share Posted October 24, 2018 Not sure if this is the right place to share this, but here goes... Used some of the excess from my damascus billet to make this little damascus hammer pendant 120 layer random pattern 1095 and 15N20 Flattened the metal out with a rounding hammer, then used a belt grinder to create the little hammer. Sanded to 400 grit, then did a few cycles in ferric chloride/distilled water. Final cut added hydrogen peroxide into the acid. All of this was done at the shop of the Master Bladesmith i am training under VID_207690720_135150_454.mp4 Quote Link to comment Share on other sites More sharing options...
tkunkel Posted October 24, 2018 Share Posted October 24, 2018 Turned out great if you ask me. Like the texture! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 24, 2018 Share Posted October 24, 2018 Going to hang it from the braid in your beard? I don't see much texture but I do see some nice topography. Quote Link to comment Share on other sites More sharing options...
Jonathan Smidt Posted October 24, 2018 Author Share Posted October 24, 2018 Thanks tkunkel. And Thomas, only did 3 etches into it, just enough for the texture that it catches your fingernails as you slide across it, but it's still really nice and smooth. It is currently sitting with my car keys now, until I can get around to making a chain to wear it from....but, I really dislike forming jump rings, so that might be a little while away. I really was more curious how it would turn out, as last month we made a 30 inch bar of Damascus, but I haven't been able to get to the shop to forge it. So, on Saturday, after my lesson covering a bladesmithing tips, techniques, etc, I pulled out the bar, and worked on one of the ends, that I already knew I wasn't going to incorporate into a knife. Hammered it out pretty randomly with a rounding hammer, to mix the pattern up a bit more, did a hot cut, and then took the disc of material I had made to the belt grinder for some quality hogging haha. Probably a bit more explanation than needed...but I was excited to be playing with it this weekend....Life's been waaayyyy too busy for me lately :( Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 24, 2018 Share Posted October 24, 2018 Have you tried bluing it and then stoning the surface to leave the tops shiny and the lower sections blued? Quote Link to comment Share on other sites More sharing options...
Jonathan Smidt Posted October 24, 2018 Author Share Posted October 24, 2018 Nope, though that sounds like a great idea! The guy I was taking lessons from mentioned I could take it to a jewlry shop and try to get it gold/silver plated, and then blue it as well, to give it a three layer effect Quote Link to comment Share on other sites More sharing options...
