June 9, 200818 yr Did you search the blueprint section? I could do it for you but I have to go to the barn in a few minutes, then out to the shop. Frosty
June 9, 200818 yr BP0189 Nails There are other Blueprints in the system which should be on line shortly.
June 9, 200818 yr rule of thumb for rivets and bolts. 2 times the diameter of the material to form a rivet head (Oval). 2.5 times the diameter of the material to form a bolt head, (square or hex). for bolts and rivets, heat just the very end (4 times the diameter) to a bright orange or yellow heat and upset the end a bit. then drop in the header and form the head. Edited June 9, 200818 yr by irnsrgn
