WacoJim Posted October 17, 2018 Share Posted October 17, 2018 All I have are pictures and measurements so far.... your thoughts? 24.5" long X 4.5" wide X 13.25" high / base approx 15.5" X 11.25" Quote Link to comment Share on other sites More sharing options...
Lou L Posted October 17, 2018 Share Posted October 17, 2018 I can’t tell the make based on those pictures. The smoothly rounded feet aren’t familiar to me but I’m certain someone here has more insight on it. My first thought is that it is a modern Russian, Chinese or otherwise less traditional country of origin. The maker’s mark would be on the other side. Either way, those dimensions tell me it’s a 300 pound anvil or close. But, once again, there are people on here who would be much more accurate in that estimation as well. In the end, you need to see it and test the rebound by dropping a large ball bearing on it. It should rebound 7.5 inches or more being dropped from ten inches. More is much better. It should also have a clear ring with no buzzing. Good luck! Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 17, 2018 Share Posted October 17, 2018 Welcome... have you read this yet? It will help you get the best out of the forum. https://www.iforgeiron.com/topic/53873-read-this-first/ Looks like a good serviceable anvil, provided it passes the rebound & ring test Lou L outlined. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 17, 2018 Share Posted October 17, 2018 Actually the bulge below the hardy and the semicircular inlet in the foot below the hardy makes it look like a Badger to me. IIRC they were a steel faced cast iron anvil and should be quiet in use---no ring, more of a thwap. It's in quite good shape so try not to abuse it as they a bit more prone to catastrophic failure and harder to do repairs on---the face is rather thin and so there is the "false casting face" to make you think otherwise. Do not grind or mill on the face! Rather like the Vulcan and Fisher anvils. Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 17, 2018 Share Posted October 17, 2018 The beginner's guide to anvil buying might be worth a read. Quote Link to comment Share on other sites More sharing options...
