Kozzy Posted October 11, 2018 Share Posted October 11, 2018 Although one could muddle through and probably get it right, I was wondering if anyone had seen information in a vintage book or other source regarding sharpening old-school tin snips. None of my old references seem to make mention of it and I was curious if there were specific tips, tricks or other info to get the old ones sharpened "right". I'm trying to bring a few old ones back into use for some tin-work demonstrations at the museum---and I'd not only like them to work as well as new (and this style never worked great in my experience) but be able to give reasonably accurate advice if a museum guest asks about fixing up the old pair Grandpa left him. Thanks for any help you can give or pointing me to any information source. I can fake it but it'd be nice to see what PEXTO or others recommended for sharpening procedures 100 years ago. Stole this photo from the internet as a reference. My pile is at home without pictures. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted October 12, 2018 Share Posted October 12, 2018 I just dust the top bevel with either a file or a stone at the original angle. You do not want to hit the side, just the tops of the blade. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 12, 2018 Share Posted October 12, 2018 Like BGD I restore a straight flat bevel using file or stone and then if extensive work had to be done I will give the inside flats one pass with a stone to remove any wire edge that might be folded over. I really like the bulldog snips for cutting bandsaw blades and pallet strapping---the ones marked "for alloy steel" (and always cut from the back of the blade and let the last hardened bit snap off...) Quote Link to comment Share on other sites More sharing options...
stevomiller Posted October 20, 2018 Share Posted October 20, 2018 If the edge is dented or flattened, I will first burnish the inside flat to try and move most of the displaced metal back where it belongs. I then do just as the gentlemen stated above. On the edge proper I often blacken just the edge bevel with a Sharpie marker so that I can see where I’m abrading. Quote Link to comment Share on other sites More sharing options...
