AdrianWood Posted May 15, 2008 Share Posted May 15, 2008 Just thought i would post an image of these coach screw heads. they were made for some acorn coat hooks i made for some oak doors and the client wanted something different to attach them to rather than plain standard screws. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted May 15, 2008 Share Posted May 15, 2008 NICE job, customer should be proud of those. Quote Link to comment Share on other sites More sharing options...
eyrian Posted May 15, 2008 Share Posted May 15, 2008 Did you machine the screws yourself, or modify existing carbon-steel screws? Quote Link to comment Share on other sites More sharing options...
simmonds Posted May 15, 2008 Share Posted May 15, 2008 Really nice work. Quote Link to comment Share on other sites More sharing options...
matt87 Posted May 15, 2008 Share Posted May 15, 2008 Purdy! Any chance of creating a blueprint? Quote Link to comment Share on other sites More sharing options...
markb Posted May 15, 2008 Share Posted May 15, 2008 Very good. Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 15, 2008 Share Posted May 15, 2008 I LIKE!! Where did you find screws that are not plated? Everything I can get are cadnium plated, haven't been able to find just plain steel. Quote Link to comment Share on other sites More sharing options...
Don A Posted May 15, 2008 Share Posted May 15, 2008 Thomas, Have you tried here:blacksmithbolt.com Don Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted May 15, 2008 Share Posted May 15, 2008 THANKS Don! I will checking them out. Quote Link to comment Share on other sites More sharing options...
AdrianWood Posted May 15, 2008 Author Share Posted May 15, 2008 Hi thanks for the compliments, the screws are bought straight from a fixings company, over here in the uk they are called square head coach screws, i believe in the states they are called `lag screws`!? They are zinc plated, all i do is use a triangle file on its edge, and file in the v shape. You can use a sharpened chisel and put the screw in a nail header tool and forge the pattern in. This is my usual method, but i was in a rush and the fire wasn`t on!! I used the torch to burn the plating off and just polished them up afterwards. Quote Link to comment Share on other sites More sharing options...
