John09040 Posted May 6, 2018 Share Posted May 6, 2018 I am looking at purchasing this big anvil but I'm kind of new and don't really know what the value of it would be. Im guessing it weighs 385lb. The guy is asking $1200. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 6, 2018 Share Posted May 6, 2018 Welcome to IFI... I always suggest reading this thread. To come up with a value it is important to know where it's located. Quote Link to comment Share on other sites More sharing options...
John09040 Posted May 6, 2018 Author Share Posted May 6, 2018 I am in West Virginia and there hard to find in our area. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted May 6, 2018 Share Posted May 6, 2018 Looks to me like the face may have been milled down, so MAKE SURE TO TEST FOR REBOUND BEFORE YOU BUY IT, or you could be stuck with a $1,200 hunk of Anvil Shaped Object!! Otherwise, looks like a very nice anvil, if you want a big one that badly... After looking at it again, are you sure that is a Fisher? No mounting lugs at the base (though an anvil that large may not need them), and the casting looks rougher than most Fishers. Ninjaanvilman would know. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 6, 2018 Share Posted May 6, 2018 At $3.11 per lb. for a fisher, in excellent condition, that's a good price IF the rebound is good. Just my honest opinion. Quote Link to comment Share on other sites More sharing options...
John09040 Posted May 6, 2018 Author Share Posted May 6, 2018 Thanks it seemed like a killer deal for a big anvil but I guess $1200 is about the upper end of the price range for it. 45 minutes ago, C-1ToolSteel said: Looks to me like the face may have been milled down, so MAKE SURE TO TEST FOR REBOUND BEFORE YOU BUY IT, or you could be stuck with a $1,200 hunk of Anvil Shaped Object!! Otherwise, looks like a very nice anvil, if you want a big one that badly... After looking at it again, are you sure that is a Fisher? No mounting lugs at the base (though an anvil that large may not need them), and the casting looks rougher than most Fishers. Ninjaanvilman would know. It says Fisher on the front foot. Quote Link to comment Share on other sites More sharing options...
RobS Posted May 6, 2018 Share Posted May 6, 2018 Beware of a painted face. That can hide things like welded repairs. Which could be good but better chance of being bad. Those edges look very sharp and the face does look alittle low. Good chance it was "repaired" Quote Link to comment Share on other sites More sharing options...
John09040 Posted May 6, 2018 Author Share Posted May 6, 2018 A few pics before he cleaned it up and welded the one place on the edge. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 6, 2018 Share Posted May 6, 2018 Looking again I see different angle grind marks on the face. Be cautious. Test thuroughly around the whole face of the anvil. Oh..... Well that does change things. I would not pay nearly as much knowing that. Quote Link to comment Share on other sites More sharing options...
John09040 Posted May 6, 2018 Author Share Posted May 6, 2018 10 minutes ago, Daswulf said: Looking again I see different angle grind marks on the face. Be cautious. Test thuroughly around the whole face of the anvil. Oh..... Well that does change things. I would not pay nearly as much knowing that. I think I will pass at $1200 he had it up for $750 at first then someone told him it was worth way more so he took it down and wants $1200 now. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 6, 2018 Share Posted May 6, 2018 With him " fixing " it, which is more hurting it, I would pass too. The other price was more reasonable. And depending how much he ruined the heat treat and IF the weld would even hold up I doubt it's worth as that much. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 6, 2018 Share Posted May 6, 2018 I'd tell him that for every rod that gets burnt on it and for every hundred of an inch removed from the face the price goes down 500 dollars. Quote Link to comment Share on other sites More sharing options...
