MotoMike Posted January 21, 2018 Share Posted January 21, 2018 disassembled, cleaned, inspected and lubricated the vise. I was amazed at how smooth and easy it operates once the old dried grease and dirt were removed and replaced with fresh grease. I thought I'd like it to look better if I did not take it down to bright metal, so just wire brushed it and then oiled the whole thing. wanting a portable mount I built this set up hoping it was rigid enough that I could fill it with sand to give it some heft. if not, there is always quick crete. but I'd like to be able to empty it to make future moving easier. the box approaches 2 cubic feet, so filled with sand the whole rig will be over 200 pounds. Link to comment Share on other sites More sharing options...
Jim Coke Posted January 21, 2018 Share Posted January 21, 2018 Greetings Mike, I think you will find filling the box with sand is mistake . I have several potable set ups . The picture is one that is quite movable and uses your body weight instead of the sand. Poor picture but you get the idea. It works great and easy to move. Good luck on your build. Forge on and make beautiful things Jim Link to comment Share on other sites More sharing options...
MotoMike Posted January 22, 2018 Author Share Posted January 22, 2018 thanks Jim. Grist for the mill. Link to comment Share on other sites More sharing options...
JHCC Posted January 22, 2018 Share Posted January 22, 2018 8 hours ago, Jim Coke said: I have several potable set ups . So drink this one in! Link to comment Share on other sites More sharing options...
Zorick Posted January 23, 2018 Share Posted January 23, 2018 Hi Jim, Nice looking mount.... What size is the vertical member ? It looks bigger than a 4" cube. Thanks. Btw I am very new to BS, so any info is appreciated. Link to comment Share on other sites More sharing options...
MC Hammer Posted January 24, 2018 Share Posted January 24, 2018 It cleaned up really nice, great job bringing it back to working order. I have a columbian waiting for me to do the same thing, but I'm waiting for better weather to tackle it outside with the wire wheel attached to the angle grinder. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 24, 2018 Share Posted January 24, 2018 On 1/23/2018 at 3:25 PM, Zorick said: Btw I am very new to BS, so any info is appreciated. Welcome to IFI... if you will edit your profile to show your location, you won't have to read a bunch of BS when you ask a question that the answer is location dependent which many are and you may be surprised how many members are near you. Link to comment Share on other sites More sharing options...
MotoMike Posted January 25, 2018 Author Share Posted January 25, 2018 MC Hammer - Thanks. I got lucky with this vise. its screw and box are pretty fresh looking. the handle was bent but I persuaded it back into straightishness. Used it tonight and it is quite a pleasure to use compared to the little bench vise I have been using. quite pleased so far. Link to comment Share on other sites More sharing options...
MC Hammer Posted January 25, 2018 Share Posted January 25, 2018 They are night and day once you get a post vise. The first post vise I got was an unmarked Peter Wright I think and it was all cleaned up except for the screw and box. I read a lot on hear before taking it apart and cleaning the screw and box. Wow, there was so much crud in the box. When I got it all clean and greased up I too was amazed at how fluid it operated. Now on to my Columbian. Link to comment Share on other sites More sharing options...
Please sign in to comment
