Cooper_kaesemeyer Posted January 2, 2018 Share Posted January 2, 2018 Does anyone know how to stop mosquitoes from leaving larvae in the water resovoir. Also to stop it from freezing I’m I’d the Pacific Northwest so I go weeks without seeing temps above freezing. And to stop algae from growing in the tank Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted January 2, 2018 Share Posted January 2, 2018 Low toxisity automotive antifreeze will address both isues. A peice if hardware cloth will improve the safety of the antifreeze. Then again 16 hours a day at the forge will boil the little buggers and keep the bosh from feezing Quote Link to comment Share on other sites More sharing options...
Cooper_kaesemeyer Posted January 2, 2018 Author Share Posted January 2, 2018 Would RV antifreeze work Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 2, 2018 Share Posted January 2, 2018 Covering the opening with a screen should help with mosquitoes, As you will be working near it as it cooks off I would look for non toxic antifreezes. Quote Link to comment Share on other sites More sharing options...
Cooper_kaesemeyer Posted January 2, 2018 Author Share Posted January 2, 2018 Thank you Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 3, 2018 Share Posted January 3, 2018 Put a drain into the tank. Drain off the water when you finish and replace it at the beginning of the next forge session. As you work the forge the water should heat up and kill the mosquitoes. Quote Link to comment Share on other sites More sharing options...
Cooper_kaesemeyer Posted January 3, 2018 Author Share Posted January 3, 2018 That’s a good idea thank you Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted January 3, 2018 Share Posted January 3, 2018 I can’t say about rv antifreeze and heat, but they do make non, or low toxisity automotive antifreeze Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 3, 2018 Share Posted January 3, 2018 They never worried about mosquitoes in the old time shops because is you did not boil the full size whiskey barrel used as a slack tub half dry by lunch, you were not working fast enough. (grin) Quote Link to comment Share on other sites More sharing options...
