John Kelley Posted October 17, 2017 Share Posted October 17, 2017 I'm sure these questions have been asked...but for the life of me I can't find this info on here with a search. ...mostly I just find something that says "I normalized..etc" I haven't even lit my forge..but I am trying to get the steps in my head if that's OK. I plan to forge a blade from 1084. I've read it's smart to normalize the blade before the quench in order to have a chance to fix any warping before the steel is hard. To normalize with a charcoal forge (if that info matters)..Do I take my shaped blade and heat it to critical/non magnetic then just let it air cool until I can hold it with a bare hand? Then check for warp..and correct either while cold or with a reheat if needed. ..or maybe just heat it...look at it..fix warp while hot..reheat..repeat? Repeat above until no warping occurs. Then...heat to non mag and quench in oil...(I plan on using canola) Hopefully no warp. If it still warps from quenching, am I right to think I can just reheat and start over the process of straightening & normalizing? Let's say I've quenched and the blade is straight..YAY..now to temper. I've read with this steel you can put it in the oven for an hour at 400˚F then let cool...and that this needs to be done 3 times. I've also read that you can temper a blade by hold the blade edge up in the fire until the edge turns straw colored then air cool...is this true? Seems strange to me that one method requires 3 hours of 400˚+cool down time and the other a few minutes....I've read it takes time to change the structure.. I'd love to be able to temper my blades with the forge...more old school or something..but only if it actually works. I know there is a TON of metallurgy science going on here..and I'm trying to learn what is going on...but it would really help to know if I at least have the steps down. AM I even close to having my mind wrapped around the process? Thank you kindly. John Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted October 17, 2017 Share Posted October 17, 2017 I will relocate this to the appropriate section and let you figure things out now that you found it Quote Link to comment Share on other sites More sharing options...
John Kelley Posted October 17, 2017 Author Share Posted October 17, 2017 I'm sorry for putting it the wrong area. I'll try to be more careful. Thank you Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted October 17, 2017 Share Posted October 17, 2017 The pinned topic in this section will answer most of your questions. However, there may still be a couple things that aren't clear to you after reading it a couple times. 54 minutes ago, John Kelley said: To normalize with a charcoal forge (if that info matters)..Do I take my shaped blade and heat it to critical/non magnetic then just let it air cool until I can hold it with a bare hand? For normalizing I heat to non-magnetic and let it cool down to black heat (not cool enough to hold in your hand) before reheating back up to non-magnetic. 52 minutes ago, John Kelley said: If it still warps from quenching, am I right to think I can just reheat and start over the process of straightening & normalizing? If you detect a warp immediately after quenching but your blade is still several hundred degrees, you can usually straighten a slight warp before it cools to room temperature. This is a little risky and you can snap a blade if you go to far. There are a couple other methods of straightening without repeating the whole process. Some people clamp a warped blade between two straight pieces of thick flat stock and leave it that way for tempering. You may also want to look into the "3 pin" method in which you isolate the warp and heat only the spine to straighten the blade. 54 minutes ago, John Kelley said: I've read with this steel you can put it in the oven for an hour at 400˚F then let cool...and that this needs to be done 3 times. I've also read that you can temper a blade by hold the blade edge up in the fire until the edge turns straw colored then air cool...is this true? Seems strange to me that one method requires 3 hours of 400˚+cool down time and the other a few minutes I've asked a similar question on here before and was told (by Thomas Powers I believe) that number of times steel is brought to a certain temperature is more important than the time spent at temperature. One of the reasons for the suggested hour or more at temperature is to make sure the entire piece of steel has been thoroughly tempered. A word of caution if you draw your temper using the color method: Once the colors start running, they go very quickly so make sure you have water or some other quench medium immediately at hand to stop the temper at the right spot. If the steel is only a few hundred degrees in temperature it will not hurt anything to dunk it in water or any other liquid that will take the heat away. Also, straw color is correct for some alloys for knife blades. It would not necessarily be correct for other alloys or applications. You'll have to look up the heat treating information for the specific alloy you are working with in order to know the proper temperatures to get the most out of that steel for your intended application. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 17, 2017 Share Posted October 17, 2017 Could have been me as the cycles are more effective than just time in shifting the structure(s). As to what color; it does depend on what the blade will be asked to do, what style it is, what are the end users preferences, etc. No magic temperature; no *best* temperature. Multiple normalizations before quenching are usually done to refine the grain structure of the steel with finer grain making a better blade. Quote Link to comment Share on other sites More sharing options...
John Kelley Posted October 18, 2017 Author Share Posted October 18, 2017 WOW! Thanks for the great replies Gentlemen! Some really good info! Thank you John Quote Link to comment Share on other sites More sharing options...
DRoberts Posted October 27, 2017 Share Posted October 27, 2017 Understanding how a crystal formation occurs in volcanic activity is much like what happens in steel. Liquid magma dumped straight into the ocean instantly solidifies, locking in the natural state of the magma. If allowed to cool slowly over thousands of years the different elements begin to clump together forming crystals. Quartz, silver, gold. Cripple Creek Colorado is an excellent geological example of this. This same concept can be applied to heat treating. Instead of thousands of years as a time metric, you're dealing with seconds. The normalizing process I find particularly interesting. If you do several normalization cycles each time lowering the temperature you take it to prior to air cooling you can produce a very fine micro grain structure. Each time you normalize the crystalline structure has time to grow as it cools. The goal is to take your metal and make the entire piece uniform in its crystalline structure, with the smallest crystal growth possible. For example, lets say you are working with CPM S110V (my favorite fillet knife material for my personal blades) stainless. This would be the correct heat treatment for the blade. All steel manufacturers include data sheets for their products. It doesn't have to be a special alloy steel, you can find these data sheets for many common metals both stainless and non-stainless. Crucible Industries makes S110V, the data sheet can be found here:http://www.crucible.com/PDFs/DataSheets2010/Datasheet CPM S110Vv12010.pdf CPM S110V much be quenched at 2150F. That would be your minimum temperature for normalization cycles. This is the austenitization temperature. It should be non-magnetic, and the lowest temperature that loosens the bonds between the crystalline lattice in the material. ~~Normallization~~ Cycle 1: Set your soak temp for 2250F and soak for 1hr. This will homogenize - think of it as almost liquidizing the crystalline structures in place, they are still there roughly but are in a state where they will reform once cooled the bonds that hold them together are broken, but they are still there "thermal memory". You will never completely get rid of them without melting down the steel. The higher your temp is the longer it takes to cool. You want to start above your quench temperature, but without excessive heat. Go with the closest margin of error your heat treat furnace can achieve. Given the same rate of cooling in air a higher starting temperature will result in larger crystals. This is important to remember. Once you start your normalization cycles you want to make sure you never cycle at a higher temperature than your last cycle. If you do it will continue to improve uniformity, but not so much the grain size. By reducing the temperature a bit on every cycle you both create uniformity of crystalline structure AND force smaller crystals by reducing the time in which the crystals have to grow. Cycle 2: Set soak temp for 2225F and soak for 30mins, air cool. This slightly lower temperature will reduce the time it takes for the steel to cool below the austenitization temperature. The crystals that formed in the first cycle will be unable to reform to their original size and the micro-stresses of the crystal formation will force the bigger crystals (thermal memory here) from the previous cycle to break up. This is very good. Cycle 3: Set soak temp for 2200F and soak for 20mins, air cool. Again lowering the temperature a bit forces the thermal memory of the previous cycle to break up even smaller. Cycle 4: Set soak temp for 2175F and soak for 20mins, air cool. At this point you have a very uniform crystalline structure throughout your steel and a very small grain structure. By stepping down your temperature each cycle you have forced less of the crystals to homogenize each time, creating an effect that fills in the gaps so to speak between the larger left over crystalline structures that formed during the first 2 or 3 cycles. ~~Quench~~ At this point you want to go for your quench at 2150F. - - Note this is below the normalization heats. If you go above your normalization heat temps you ruin the work you have done by the step down cycle. Make sure you never do this, never quench from a heat higher than your normalization heats. This is an extremely important concept - the longer your steel remains takes to cool the larger your grain structure will be. You want your steel conditioned perfectly by the normalization process so that when you go for a quench you can do it right at the austenitization temperature. If you skip the normalization structure you lock in whatever stresses and non-uniform crystal growth size is in the steel. This is why you see smiths on forged in fire quenching at cherry red end up with high performing hardness and those quenching at bright yellow end up with chipping and rolling. Both are hard, but only one is strong. This is also why quenching in water is very dangerous for steels with high rates of crystalline formation. Where pure iron may survive, high carbon alloy steel with very complex crystalline and even carbide micro structures just shatter like glass under that amount of stress. After the quench the uniform/tiny crystal formations are set. ~~Temper ~~ Set soak temp for 975F and soak for 2 hours. Make sure it completely cools to room temp each time. Repeat 2 more times. Quote Link to comment Share on other sites More sharing options...
John Kelley Posted October 28, 2017 Author Share Posted October 28, 2017 WOW! Thanks for the great response! really liked this part.... "Once you start your normalization cycles you want to make sure you never cycle at a higher temperature than your last cycle. If you do it will continue to improve uniformity, but not so much the grain size. By reducing the temperature a bit on every cycle you both create uniformity of crystalline structure AND force smaller crystals by reducing the time in which the crystals have to grow. " Quote Link to comment Share on other sites More sharing options...
