Kaowool and Flux
I was wonder what I can do to protect my kaowool for the flux when trying to forge weld damascus. I will be putting Plistix 900F on it but will that be enough to protect it?
I was also wonder if it would work to put a piece of metal in the bottom on top of the kaowool to protect from the flux?
Any info would help!
Thanks
Nitro
You could use satanite or somesuch, or make a slurry with castable refractory and paint that on.
Merry being,
Archie
so I would put the satanite or somesuch on the blade instead of the borax flux and it work the same.
Nitro
I am just getting in to it. so Im trying to get my forge setup for damascus.
Nitro
some people put a firebrick in the bottom of forge for the flux to get on when it gets really gummed up throw it away and put a new one in there...
I do a lot of forge welding in my gas forges. I cover the ceramic fiber blanket on the bottom half with about 2 inches of ram refractory (or plastic.) The flux will not damage this stuff and actually puddles with scale in the bottom after it builds up and can be scooped out while hot and molten. The best stuff I have used is AP Green's Green Pack 85, ANH Refractories
I used bubble alumina in the bottom of my forge - from Darrin Ellis. He said it was the best he had seen for resisting flux ( haven't taken it apart to see what shape it is in ).
Ken
IIRC Hrisoulas has used a metal try with cheap kitty litter in it as a flux catcher---probably need to support the billet above the tray so you don't stick litter to it though.
Thanks
Nitro
I've made a plate from castable refractory to deal with this issue.
Thank you all for the info. This has been really helpful.
Nitro
