PapaDooks Posted April 2, 2017 Share Posted April 2, 2017 don't even know if that's the right name for bottom blowing or not but i was wondering if exhaust pipe was "safe" to use for this purpose? would i need to de-gal it first if it was galvanised piping ? Quote Link to comment Share on other sites More sharing options...
turbo7 Posted April 3, 2017 Share Posted April 3, 2017 If it was gal pipe mate I wouldn't use, not even worth the risk. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 3, 2017 Share Posted April 3, 2017 Or chromed. Especially chromed. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 3, 2017 Share Posted April 3, 2017 I made mine with plain steel semi truck exhaust pipe I took out of the scrap pile at the heavy duty shop. It works beautifully in both senses. It made an excellent tuyere AND it's easy to work with. I used 4" for the vertical section and 2" for the horizontal supply. Matching them to weld is as easy as buying a 2" hole saw blade. I just drilled the 4" pipe where I wanted the supply to enter, IIRC about 3" below the air grate and 6" above the ash dump. I had a brainstorm and instead of trying to mark and cut the 2" to match with a jig saw I clamped it in my V block on the drill press and used my 4" hole saw. Once again I used the 4" hole saw to cut the opening in a piece of 14ga. to serve as the mounting flange under the forge. Then I just mig welded it all together Oxy acet welds are easy peasy on exhaust pipe as well. For the last bit of construction I stuck it against the bottom of the forge and drilled 4 screw holes. The air grate just lays over the tuyere and mounting screws. The ash dump is a semi truck exhaust flap cap clamped upside down on the bottom. The counter weight is aimed at the operator position so it's easy to give it a flip open with a hammer, tongs, piece of stock or anything almost a foot long, say 20cm. That's it, easy peasy and works a treat. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
