StumpingIron Posted March 25, 2017 Share Posted March 25, 2017 I am not sure if I should put a handle on this knife or make some textures on the metal can someone please tell their thoughts? Quote Link to comment Share on other sites More sharing options...
AnBello Posted March 25, 2017 Share Posted March 25, 2017 In my own personal opinion, I would go for a wooden handle, because I believe it would most likely feel too heavy on the back if not. I think there is a reason why metal handled knives aren't very common (although sometimes going against what is common has its merits). I would also like to know more about the knife itself. What will be it used for? What steel is it? Quote Link to comment Share on other sites More sharing options...
TacticallySharp Posted March 25, 2017 Share Posted March 25, 2017 10 hours ago, StumpingIron said: I am not sure if I should put a handle on this knife or make some textures on the metal can someone please tell their thoughts I would use G10 and that would waterproof it for use in the kitchen. Quote Link to comment Share on other sites More sharing options...
StumpingIron Posted March 25, 2017 Author Share Posted March 25, 2017 Thanks for letting me know and it is going to be used as a sort of scribe for wood and also other things like a box cutter but the scribe is the main use and for the steel I have no idea I just picked a massive bar of it out of my friends backyard but it is very flexible but it is not hardened also the metal is 5mm thick thanks again. Quote Link to comment Share on other sites More sharing options...
JHCC Posted March 25, 2017 Share Posted March 25, 2017 There's something I find aesthetically appealing about that big chunk of steel, so maybe a cord wrap to allow those lines to show through would be nice. Whatever you do, it does look like it's going to need at least a bit of sharpening: that edge looks just a little blunt. Quote Link to comment Share on other sites More sharing options...
StumpingIron Posted March 25, 2017 Author Share Posted March 25, 2017 yeah I only just finished profiling the knife and I am going to do a chisel grind on it Quote Link to comment Share on other sites More sharing options...
Will W. Posted March 26, 2017 Share Posted March 26, 2017 Hot cut chisel sort of edge or cold chisel sort of edge? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted March 28, 2017 Share Posted March 28, 2017 On 3/25/2017 at 2:21 AM, StumpingIron said: Thanks for letting me know and it is going to be used as a sort of scribe for wood and also other things like a box cutter but the scribe is the main use and for the steel I have no idea I just picked a massive bar of it out of my friends backyard but it is very flexible but it is not hardened also the metal is 5mm thick thanks again. For that use, I would forge it with a pineapple twist and ball for the pommel. Quote Link to comment Share on other sites More sharing options...
StumpingIron Posted March 28, 2017 Author Share Posted March 28, 2017 Nah mate my forge is not set up yet I just need 2 more pipes for the burners and then I can start forging Quote Link to comment Share on other sites More sharing options...
BlasterJoe Posted March 30, 2017 Share Posted March 30, 2017 I think flat cord wrap. Some 750 cord with the innards pulled out. Maybe a camo pattern. Quote Link to comment Share on other sites More sharing options...
