ronwend523 Posted February 22, 2017 Share Posted February 22, 2017 I fired my newly built small forge for the first time, today. I have never done that before. I used some Kingsford because I have not made any charcoal yet. I'm just getting into this stuff. I put a piece of steel in the fire and she got close to white. I had an issue with the blower I had put on it as it didn't put out much air. I put my hair dryer in it and away it went. I have to revamp that part. The forge is an old camper sink(stainless) and I made some refractory and lined it behind some fire brick. I have to make a grate for the bottom draft hole yet. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 22, 2017 Share Posted February 22, 2017 Remember you should be able to put the workpiece horizontally into/through the hot spot Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 22, 2017 Share Posted February 22, 2017 What Thomas said, and you may want to extend the ash dump. I would be a little concerned having the plastic pipe right at the T connector. A little further back isn't a concern since that doesn't get hot there but Hot ashes find their way on the inner ledge of the T connector. If im seeing it right I like the butterfly valve in the pipe idea. Quote Link to comment Share on other sites More sharing options...
ronwend523 Posted February 23, 2017 Author Share Posted February 23, 2017 Thank you for the tips guys. Daswulf I saw that too and took the plastic off. I will extend that with a 6" nipple then the plastic. I'm going to go with a hair dryer as my fan for now and see how that goes. I'm not going to be forging as much as you guys would. I'm thinking with I may need to raise the bottom of my burn area up to get a hot spot higher for mid piece heats. Making the refractory stuff was easy so that would work. I may need to extend an area all around the hot box for additional fuel to rake in. I enjoy any feed back guys. Quote Link to comment Share on other sites More sharing options...
