angiolino Posted February 6, 2017 Author Share Posted February 6, 2017 Temporarily use a sheet metal plate big iron, if I can find a used anvil, I also find the condiziioni moving and shipping, someone accidentally built the blacksmith's tongs,. I use pliers to parrot as remedied? thanks for valuable suggestions, or old railroad iron, rails, beams or plates or junkyard mechanic, I'll see if I can find a suitable piece of heavy metal massive recovery thanks again Mod Note: Copyrighted image removed. Quote Link to comment Share on other sites More sharing options...
AdamG Posted February 10, 2017 Share Posted February 10, 2017 Why not make your vertical piece twice as thick? Just weld squares together until you get a rectangular prism that's at least 4"x6" on top. You can weld on harder steel if you like, or a hardie hole on the side, but just get a mass of steel together and start pounding! With that much iron, you can make ten of them, all in different shapes! Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 11, 2017 Share Posted February 11, 2017 Do your level best to get the top plate full thickness welded deep filets on the laminated plates and even plug welds. Honestly, buy the time you have used up the consumables, you can buy a foot square drop 4" thick (30cm x10cm) or a 15cm round drop from a machinist 30cm high. Quote Link to comment Share on other sites More sharing options...
angiolino Posted February 11, 2017 Author Share Posted February 11, 2017 superimpose various plates, it seems a good idea if you have other ideas or suggestions I invite you to sottopormeli thanks again, maybe drawings or illustrative photographs thanks again https://i.imgur.com/FPtrt.jpg https://i70.photobucket.com/albums/i98/buddknives1/anvil2.jpg https://meriwethercycles.files.wordpress.com/2012/07/baseplate-jman.jpg http://gilblog.com/anvil.jpg https://mikescustomweaponry.files.wordpress.com/2014/04/20140426-202840.jpg?w=440 Quote Link to comment Share on other sites More sharing options...
