Neal L Posted February 11, 2008 Share Posted February 11, 2008 I have poured my babbitt bearings in the blower I found. Thanks for the help!!! It turns real easy and I think it will last a long time. My next question is what speed should I try to make the blower turn to get enough air for my forge? I plan to put in a slide gate to control the flow and let the blower run at one speed. The blower shaft has a 1 3/4 flat belt drive. I have a motor from a squirrel cage blower that came out of an old heater. It turns 1725 rpm's. I appreciate any suggestions. Quote Link to comment Share on other sites More sharing options...
jayco Posted February 11, 2008 Share Posted February 11, 2008 I have a blower much like yours that I use an old washing machine motor and a v-belt for power. 1750 rpm motor. I've never really rigged up an adequate air gate on mine.......Mine blows like a leaf blower or 'hurricane' You'll have no problem getting enough air! Quote Link to comment Share on other sites More sharing options...
Neal L Posted February 11, 2008 Author Share Posted February 11, 2008 ApprenticeMan, Once i shot a little grease in her she turns with hardly any drag at all and i cant feel any play in the bearings. so i'm pleased with the outcome. Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 11, 2008 Share Posted February 11, 2008 Neal Go to the top of the forum page and click on User CP Click on edit profile go to the bottom of the page, enter your location and save. We would like to know where in the world you are located. Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted February 11, 2008 Share Posted February 11, 2008 Neal, did you get any pictures of the procedure. I have a similar blower in need of the same treatment. Thanks bruce Quote Link to comment Share on other sites More sharing options...
Neal L Posted February 12, 2008 Author Share Posted February 12, 2008 I didn't take pictures as I went. The side of the blower with the pulley was worn really bad so I removed the old material from that side first. I replaced the shaft with a piece of 5/8 round stock, put the two halves of the blower back together and centered the shaft with a plastic 5/8 bushing and some tape around it to get it up to the sizes of the hole. I used a flat washer with some high temp copper RTV silicon gasket maker to hold it in place and keep the molten babbitt in place. I heated the housing to about 400 degrees the the acy torch. I heated the Babbitt in the ladle on a propane burner to around 650-700 degrees and poured it in until it was full. Oh, I used an infrared gun to measure temperature. I went away until the thing cooled. I had to drive the 5/8 rod out with a brass punch then i used the dremel tool to sand the inside diameter until the shaft fit freely. The I repeated the same process on the other side of the housing. I need to get better at remembering to take pictures i guess. I hope this helps Quote Link to comment Share on other sites More sharing options...
Neal L Posted February 12, 2008 Author Share Posted February 12, 2008 Updated the profile Glenn Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 12, 2008 Share Posted February 12, 2008 Thanks, it makes things much easier. Quote Link to comment Share on other sites More sharing options...
brucegodlesky Posted February 12, 2008 Share Posted February 12, 2008 Thanks Neal, that don't seem too difficult. Sumter anywhere near Bluffton? My youngest lives there. Quote Link to comment Share on other sites More sharing options...
Neal L Posted February 12, 2008 Author Share Posted February 12, 2008 Bluffton is a couple hours away from me. Sumter is in the center of the state about 45 min, east of Columbia. Quote Link to comment Share on other sites More sharing options...
