Kurogane Posted November 26, 2016 Share Posted November 26, 2016 I have been commissioned to forge some medieval heads, I've made the bodkins, the heavy bodkins and now they want some swallow tail heads, o told them I'd try but absolutely no promises, I'm mind boggled thinking on howbto forge them. I'm thinking they upset the stock and forged the edges then bent them out to make the socket, anyone have experience of can give a tutorial? Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted November 26, 2016 Share Posted November 26, 2016 If you get a keyboard with a SCROLL key , you could have scrolled down the page a bit and seen we have an entire section devoted to things like this, allow me to relocate this thread there for you to make it easier to find the information on arrow heads. Quote Link to comment Share on other sites More sharing options...
Kurogane Posted November 26, 2016 Author Share Posted November 26, 2016 On 11/26/2016 at 3:37 PM, Steve Sells said: I apologize, I searched and didn't come up with anything besides discussions, and I am on a mobile device Quote Link to comment Share on other sites More sharing options...
wpearson Posted November 27, 2016 Share Posted November 27, 2016 is this what your looking for Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 27, 2016 Share Posted November 27, 2016 Seems rather trivial as easily as real wrought iron can be welded. Even allow you to steel the edges though that appears to not have been common IIR David Starley's talk on Medieval Arrowheads at the 37th annual International Congress of Medieval Studies Conference. Quote Link to comment Share on other sites More sharing options...
Kurogane Posted November 27, 2016 Author Share Posted November 27, 2016 Thanks guys, and I'm using mild steel, I like trying to figure out how they made the items in the past, but these I dunno, I was thinking forum the blade and bent the barbs aside to make the socket Quote Link to comment Share on other sites More sharing options...
basher Posted August 16, 2017 Share Posted August 16, 2017 There are numerous ways you can achieve this shape, the method you sujest will work but neesd some specialist tooling to support the barbs. there would also be a couple of ways to forge weld it together. Doing it small enough is the challenge, I woiuld start bigger and then scale down once you have a method that works. Quote Link to comment Share on other sites More sharing options...
