tonyw Posted November 5, 2016 Share Posted November 5, 2016 This anvil has no markings except a "70" cast proud under the horn. The base has a uniform hour-glass indentation. There does seem to be weld line at the waist? Is this anvil cast or not? Please see the pictures. Thanks. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted November 5, 2016 Share Posted November 5, 2016 from the pictures, i would say with a fair amount off certainty, that you have a Vulcan. that would make it cast iron with a steel face plate. Quote Link to comment Share on other sites More sharing options...
tonyw Posted November 5, 2016 Author Share Posted November 5, 2016 Thank you tubalcain2 Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted November 18, 2016 Share Posted November 18, 2016 I know I'm late for this post, but I'd say the face plate is way too thick to be a Vulcan. Maybe Fisher? Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted November 18, 2016 Share Posted November 18, 2016 6 minutes ago, C-1ToolSteel said: I know I'm late for this post, but I'd say the face plate is way too thick to be a Vulcan. Maybe Fisher? Not a fisher.i've seen vulcans with face plates that thick. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted November 18, 2016 Share Posted November 18, 2016 You're right. I just looked it up, and they're all over the place. My bad. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted November 18, 2016 Share Posted November 18, 2016 yeah, i thought u knew i'm always right about anvils. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted November 18, 2016 Share Posted November 18, 2016 Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted November 18, 2016 Share Posted November 18, 2016 Josh, owner of the Fisher Museum, has stated repeatedly that Fishers only had a 1/2" thick steel face. The appearance of a thicker face was a "foundry trick" to make the steel look thicker but was just the cast iron pattern below the steel widened to give the appearance of a thicker face. Broken face Fishers that I've seen give me no reason to doubt this, the plates do indeed seem to be about 1/2" thick. Busted Vulcans that I have seen have thinner steel faces in my experience, 3/8" to 1/4" thick. If you look closely at the last photo above you can see a slight change in color and texture to the big built up edge almost in line with the step. That is the steel face/cast iron transition. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 18, 2016 Share Posted November 18, 2016 The no steel face all cast iron anvils also often use the "fake face" method; so much so that I generally steer clear of any anvil with a face protruding on the sides, Quote Link to comment Share on other sites More sharing options...
njanvilman Posted November 18, 2016 Share Posted November 18, 2016 Judson Yaggy is correct about the face on the above anvil. It has a steel face probably about 5/16" thick over the cast iron. The anvil is probably a Vulcan with the described markings. Fisher, and Vulcan on some their anvils, but not all, made the iron under the face wider than the body, both to support the steel and to give the appearance of a thicker faceplate. I also think that this was to serve as an area that could be ground back to reveal a new edge if the present one got damaged. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 18, 2016 Share Posted November 18, 2016 Now that would be a Feature, especially for Vulcans.... Quote Link to comment Share on other sites More sharing options...
