Glenn Posted February 2, 2008 Share Posted February 2, 2008 Great welders make great welds that need no additional clean up to look good. The rest of us may sometimes need a grinder clean the welds up a bit and or smooth them out. Does grinding the surface of the weld scratch or score the metal in such a way that it makes it easier to start a fracture at the scratch line and break? Does the direction of the scratching matter? Does putting a radius on the weld (through grinding) weaken the weld? I am not talking about digging back into the parent metal just knocking the top off the weldment which leaves a radius. Quote Link to comment Share on other sites More sharing options...
Ice Czar Posted February 2, 2008 Share Posted February 2, 2008 may sometimes you obviously haven't seen me weld Im certainly not an old hand at welding, but its been a daily activity for the past 7 months, (as has grinding them ) What I can say is the with good penetration, the weld should hold even ground, but with a bad weld grinding off part of the bead will increase the odds of it breaking. Also, often there is little choice as to the direction the grind must occur, scratches are minimal with a sanding disc following the hard wheel. Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted February 2, 2008 Share Posted February 2, 2008 Depending on what it is, most likely no. As long as you get good enough penetration that is. But, I would recommend grinding with the length of the weld. I mean, if the weld goes like this: --------, then grind like this: --------. And making the finish as smooth as possible will help alot. Quote Link to comment Share on other sites More sharing options...
R Funk Posted February 2, 2008 Share Posted February 2, 2008 Grinding a weld smooth can actually reduce the likehood of cracking in some cases. For example when splicing a truck frame to lengthen the truck, it is recomended that the welds be ground absolutely smooth to minimize "stress risers" Stress risers are changes in the shape of the steel. It could be a notch, a hole or a change in thickness, such as a weld. For fillet and corner type welds this is not as critical. Just try to keep the size of the weld approximately equal to or larger than the thickness of the material being welded if strength is needed. Quote Link to comment Share on other sites More sharing options...
Rutterbush Posted February 11, 2008 Share Posted February 11, 2008 Unless a sharp edge is left, or a thin spot, nothing may ever happen on a stationary piece. Put that same weld on a front end loader or something huge that may have cyclical movement and it could be disasterous. It usually depends on the use. An example that comes to mind, some welding procedure specifications for code welding require grinding the weld to a certain conture on the face of a fillet weld. This procedure may or may not specify the final surface finish. Ornamental iron only needs to look good and keep the kids from breaking the weld and you from meeting their lawyer. Of course, there's that part about keeping rain out of the tube stuff. Again, it depends on what the end result needs to accomplish. In the very large picture, way out in right field, any scratch on metal could be a potential crack. With this said the direction of grinding would be suggested that the grinding scratches should be toward the direction of possible bending. This way the scratch lines will bend with the metal. Hold your hand palm out. Bend your hand as if to hold a hammer handle. The fingers curl around easily and do not seperate. If the grinding scratches go transverse or across the potential direction of bending the scratches will tend to stretch and open. Hold your hand palm out. Put the end of the hammer handle in the palm of your hand and attempt to wrap your fingers around the end of the handle without spreading or bending the fingers. Clear as mud? Quote Link to comment Share on other sites More sharing options...
Ice Czar Posted February 12, 2008 Share Posted February 12, 2008 yes for say pressure tanks, boilers, bridges, elements with torsional stress ect (aircraft carriers) Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted February 12, 2008 Share Posted February 12, 2008 There are also some welding procedures that specify that if you grind or even wire brush your weld, you automatically fail. No excuses, no exceptions. Rutterbush is completely correct in correcting me about the direction of grinding and I thank him for doing so. IDK what in the world I was thinking, but he is correct. Grind in the direction of the highest possible stress. In some cases, if you just need something to hold, I've known people to just take a 6010 rod, crank up the amps and burn that baby in. And then take a 7018 and go over it in several passes and just grind it off to make it look good. All-in-all, Rutterbush is most certainly correct. It all depends on what it is being used for. Quote Link to comment Share on other sites More sharing options...
clw1985 Posted February 13, 2008 Share Posted February 13, 2008 most things i do, i just grind that dude off...if im doing something that will be under alot of load but the weld is required to be ground off.....from what iv'e read and understood, if the weld goes east and west, grind norht and south vice versa...because the grind marks can weaken it if done wrong........i haven't really had any bad experiences grinding. i had a cwi as an instructor and he explained that all to us. he was picky and, usually right. Quote Link to comment Share on other sites More sharing options...
Rutterbush Posted February 13, 2008 Share Posted February 13, 2008 I didn't intend any corrections to anyone's post. Sorry if it read that way. I was only making comment. Short version of grinding marks left on the weld when grinding is complete, the marks, or scratches, should run with the direction of welding or longitudinally. Hillbillysmith shows a good example in post #3. Quote Link to comment Share on other sites More sharing options...
jimmy seale Posted February 13, 2008 Share Posted February 13, 2008 welders here that weld on well heads string in mild- 6010 i think then tie in w/ 7018 clean up inbetween and then cap w/ 7018 to temper the weld- but they don't use that bead to tie to the parent metal- if you are confussed well. join the club. Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted February 13, 2008 Share Posted February 13, 2008 What you do is do a root pass (that's the first pass in the groove) with 6010 and then weld stringer beads with 7018 the rest of the way to the top and then do a weave bead with 7018 for a cap pass to fill in and seal the weld off. Not to temper it on MILD steel. Just to try and clear up any confusion. Quote Link to comment Share on other sites More sharing options...
Rutterbush Posted February 29, 2008 Share Posted February 29, 2008 If the well heads are being welded to code, API 1104, then there is a welder who is not in compliance. At least, not the code I'm reading. The whole point of welding is to make two, or sometimes more, separate pieces of metal into one. However, there is a consideration to everything, such as, WHY? 1-Is the weld metal of the cap/cover too low and there is a need to fill it up? The weld should be a maximum of 1/8" above the base metal. 2-Is the completed weld leaving the edges of the bevel exposed and not part of the weld? An inspector would interpret this as lack of fusion or under fill. The weld should be 1/64" over, or past, the top edge of the bevel on each side. There's an old saying that the cover pass should be a "Dime high and nickel wide". As for tempering a weld? There is Pre/Post Weld Heat Treatment. Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted March 1, 2008 Share Posted March 1, 2008 There are also some welding procedures that specify that if you grind or even wire brush your weld, you automatically fail. No excuses, no exceptions. All-in-all, Rutterbush is most certainly correct. It all depends on what it is being used for. Thats how it was when i took my 6G 7018 test. No grinding just a little pick. And the inspector stood by you the whole time and watched...Bob Quote Link to comment Share on other sites More sharing options...
rawblacksmith Posted April 17, 2008 Share Posted April 17, 2008 the more you know, the more you know you don't know! now i have to start all over learning welding...concentrating on metallurgical knowledge demonstrated here...you guys make me worry about every weld i've done before! i started out as a d.o.t. certified train car repair welder, then worked a short time in a police car muffler plant (i made them wrong on purpose!!), steam power r&d, and finally , my last welding job before going indie....highly decorative welding of structural pieces..staircase railings, spiral staircases, bridges, etc.... with that work EVERY weld is ground to remove all traces of welding... goal is to make every piece look like it was sculpted; especially in pieces that were of organic motif. (see my wine cellar pieces) i always worried about the scientific facts regarding such welds...always used whatever the man provided and remained ignorant about such things as we are discussing here. now that i am starting over, along with new shop with new tig/stick machine and the new skills to be acquired, the liability is mine. i want the other edge of the liability sword; that of the good reputation for great artistic work. you guys make me want to go ahead and start in first day welding classes, but i always find it a crap shoot for who's would teach...i always got lucky and paid to learn instead of paying. well now i'm paying anyway....electricity is higher here in hawaii than anywhere else, and argon was $130 to fill bottle!! (they have to send bottles over to oahu to fill) that gives me impetus to gain master proficiency on stick! i'd only ever been proficient in mig and o/a welding before. never saw a tig machine until i bought one last month. well all this makes forging all the more important to me...so much cheaper to do here than welding with electricity. Quote Link to comment Share on other sites More sharing options...
KYBOY Posted April 21, 2008 Share Posted April 21, 2008 When I passed my first stress test it was a ground smooth weld. If your careful and the penetration is good grinding a weld shouldent hurt it. the most important part of a weld in the "inside"....;) Quote Link to comment Share on other sites More sharing options...
