AZGUY Posted May 3, 2016 Share Posted May 3, 2016 Picked this up the other day, Craigslist find for $80. The cheapest I have seen in a while. Does anyone make a replacement spring for these? I know most people make their own but I don't think I know enough yet to put the tool at risk of a bad part. Disassembly and clean up begins soon. Anything I should watch out for? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 3, 2016 Share Posted May 3, 2016 Considering that you can make a spring for it by just bending a piece of mild steel cold; perhaps you do know enough... Do remember to take apart the pivot area and clean and oil it as that will help a lot with the spring working well. Quote Link to comment Share on other sites More sharing options...
AZGUY Posted May 3, 2016 Author Share Posted May 3, 2016 I don't need any particular type of spring steel or anything? Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted May 3, 2016 Share Posted May 3, 2016 Nah, spring steel isn't necessary for this application. All you need is something that will tension a little bit when its closed so that it opens with ease. Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted May 3, 2016 Share Posted May 3, 2016 is it also missing one of the keys/wedges, sorry I couldn't quite tell from the picture. there should be two. Littleblacksmith Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 3, 2016 Share Posted May 3, 2016 Not a problem and now you can make it to fit with your new spring installed! Quote Link to comment Share on other sites More sharing options...
AZGUY Posted May 4, 2016 Author Share Posted May 4, 2016 Is the wedge what keeps it tight against the mount? Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted May 4, 2016 Share Posted May 4, 2016 yes. Littleblacksmith Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 4, 2016 Share Posted May 4, 2016 You're lucky; most cheap vises are missing the mounting hardware. Nice find! Quote Link to comment Share on other sites More sharing options...
oldshove Posted May 4, 2016 Share Posted May 4, 2016 heres a couple of pic,s of the wedge and spring looks like Quote Link to comment Share on other sites More sharing options...
AZGUY Posted May 5, 2016 Author Share Posted May 5, 2016 Awesome, thank you. Quote Link to comment Share on other sites More sharing options...
