yt12 Posted February 18, 2016 Share Posted February 18, 2016 Good Day All-----I have acquired a quantity of "test samples"-----pieces 1" x 3 "x 1/8 and 1/4.These were acquired at an auction held to settle an estate.The big 3 are 85.5% fe 7.6% ni 4% co----I was considering them as edge inserts for axe heads/knife blades.Worth the effort ?!?!.I call them test samples as the gentleman whose estate they came from was a respected fabricator/tester for many,including Lockheed and Battelle.As time permits,I may post a "it followed me home"-----you may not like me after reading it !!! Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 18, 2016 Share Posted February 18, 2016 forgeable? most likely but no carbon = will not harden Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 18, 2016 Share Posted February 18, 2016 No carbon? Doesn't sound like edge material to me. Quote Link to comment Share on other sites More sharing options...
Buzzkill Posted February 18, 2016 Share Posted February 18, 2016 You said the big 3 (I assume percentage-wise). There's still 2.9% unaccounted for, so we just don't have enough information to answer the question. If the carbon is over 0.6 it's probably decent edge material, but without knowing the carbon content we can't tell you more. Quote Link to comment Share on other sites More sharing options...
yt12 Posted February 18, 2016 Author Share Posted February 18, 2016 Thank you for the feed back,it is appreciated.I was not on my A game when I had the pieces tested----will get them scoped for carbon and go from there---Thanks again !! Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted February 21, 2016 Share Posted February 21, 2016 cut of a piece of one of 'em of, beat on it, normalize it, quench it in oil- if that doesn't work, than quech it in water. if it doesn't hardin than just use it how you would mild steel. Littleblacksmith Quote Link to comment Share on other sites More sharing options...
