D H B Posted December 30, 2015 Share Posted December 30, 2015 Any ideas, or just some random junk? Quote Link to comment Share on other sites More sharing options...
matto Posted December 30, 2015 Share Posted December 30, 2015 It is a wagon vise. The holes. In the base are for u bolts that go around the tong of the wagon. Nice little vise. Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted December 30, 2015 Share Posted December 30, 2015 Looks the kind of tool that will do a lot of things badly. As opposed to a tool which does only one thing, but does it well. Alan after matto's comment... it is the sort of all-rounder like a leatherman multi tool which is handy when working on site. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted December 30, 2015 Share Posted December 30, 2015 Greetings DH, Not a wagon tongue vise.. This is a common bench vise offered by many suppliers in about 1900. You are missing a pin that limits the opening.. They open very wide and are a handy addition to your shop. They are cast so limited use of the anvil end.. Put a pin the hole and give it a try,, Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
njanvilman Posted December 30, 2015 Share Posted December 30, 2015 It looks like there is a braze repair on the movable jaw. Might or might not affect its operation. It does show that it was over-tightened at some point or had a bad casting. Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted December 30, 2015 Share Posted December 30, 2015 14 hours ago, Jim Coke said: Greetings DH, Not a wagon tongue vise.. This is a common bench vise offered by many suppliers in about 1900. You are missing a pin that limits the opening.. They open very wide and are a handy addition to your shop. They are cast so limited use of the anvil end.. Put a pin the hole and give it a try,, Forge on and make beautiful things Jim I have not seen one of these before...Presumably the shear pin enables the quick or coarse setting for the jaw opening, and the screw thread then does the fine? Alan Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted December 30, 2015 Share Posted December 30, 2015 Greetings Alan, Correct.. The initial opening width is established by the pin adjustment Than final closure by the screw thread .. Should open to almost a foot.. Handy tool when you need it.. I keep one mounted in a tri-stand and use it a lot . Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
