pokers
stan
3 hours ago, ThomasPowers said:
I'm not a fan of the square transition of the 2nd and 3rd one down but the bottom two makes me wonder about a modification to make the back end a spike---like 1/2 an arrow head to be both poker and puller.
Yes when the bottom two are  used as a puller they do tend to slip the arrow point would solve that problem.
I like 'em all. All different. Stylish.
40 degree C heat up here too, Stan, but high humidity as well. Storm season.
You might not need pokers for a log fire in the home right now, but hey .. summer barbecues ... gotta keep the barby fire under control!B)
31 minutes ago, stan said:
Thanks Daswulf I like making pokers there's no restriction on design as long as they do the job
I'd agree. The last two are odd designs to me on the poker side but if they work, as you said they do, then I like em. ;) I do want to say your forge welds all look great. It's something I have yet to accomplish. Well done.
Thanks Daswulf, but I have to say that those joins are stick welded then re forged ,with a small gas forge I find it easier and quicker. Cheers.
