gote Posted August 25, 2015 Share Posted August 25, 2015 Post vise. A former owner broke the post and welded an L-bar to it. The jaws are 41/2" This vise differs in the bracket from most vises shown here. The vice is intended to be able to pivot around a vertical axis. There is a hexagon head screw at the back that normally locks it and the "bearing" is pulled thight by two screws that have holes for turning. The movable jaw is not only pivoting around the bolt, there is also a circular bearing surface (which I understand is German style). It is of course impossible to rotate the vise with the L-bar extension to the post. I wanted to turn it as late as last week. It is my intention to remove the L-bar and to heat a tube to red and knock onto the post. (I got the idea in this forum. Thank you very much whoever it was) I am sure it will shrink to a sufficiently strong fit. I will then turn a pivot, cast a plug of concrete into my dirt floor and put a piece of steel plate with a hole for the pivot. Or put a stud onto the plate and use the pipe as bearing. As you can see I have fixed it to the work bench. All post vises i have sen in Sweden have been fixed this way and I find it practical to be able to put any tool I need on the bench. Quote Link to comment Share on other sites More sharing options...
gote Posted August 25, 2015 Author Share Posted August 25, 2015 (edited) Post vise. A former owner broke the post and welded an L-bar to it. The jaws are 41/2" This vise differs in the bracket from most vises shown here. The vice is intended to be able to pivot around a vertical axis. There is a hexagon head screw at the back that normally locks it and the "bearing" is pulled thight by two screws that have holes for turning. The movable jaw is not only pivoting around the bolt, there is also a circular bearing surface (which I understand is German style). It is of course impossible to rotate the vise with the L-bar extension to the post. I wanted to turn it as late as last week. It is my intention to remove the L-bar and to heat a tube to red and knock onto the post. (I got the idea in this forum. Thank you very much whoever it was) I am sure it will shrink to a sufficiently strong fit. I will then turn a pivot, cast a plug of concrete into my dirt floor and put a piece of steel plate with a hole for the pivot. Or put a stud onto the plate and use the pipe as bearing. As you can see I have fixed it to the work bench. All post vises i have sen in Sweden have been fixed this way and I find it practical to be able to put any tool I need on the bench. Edited August 25, 2015 by gote pictures missing Quote Link to comment Share on other sites More sharing options...
matto Posted August 25, 2015 Share Posted August 25, 2015 nice vise, you can weld a stub post on also. as for on the bench it works but it is also nice to be able to walk all the way around the vise. depends on what you are doing. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted August 26, 2015 Share Posted August 26, 2015 Very nice. I like the tension screw/set screw on the mount, and the shoulder on the pivot point to keep crud from getting in the joint. Quote Link to comment Share on other sites More sharing options...
gote Posted August 26, 2015 Author Share Posted August 26, 2015 As you say it depends upon what I am doing. If I can get the turning to work it will be versatile enough. Somehow I prefer to have the bench surface in the immediate vicinity and as you can see, it is intended to be bench mounted.Göte Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted August 26, 2015 Share Posted August 26, 2015 (edited) Most of my leg vices have a collar welded on the bottom of the leg, maybe 40mm (1 1/2") from the tip. If you had something like that you could just have a block in the floor with a hole in it. The collar will take the hammering down thrust and the projecting pin will both locate and also allow the vice to swivel.An oak block with the locating hole in the end grain would work well.@matto...I would imagine that it was always intended to be a bench mounted vice hence the swivel. As you say you can walk all around a post mounted vice so there is a reduced need for the swivel facility.I always find it useful to have somewhere to put tools down while adjusting the workpiece in the vice. My main vice I mounted on a tripod frame with a piece of plate as a tool rest / bench. It was home fabricated version of the classic cast iron 3 legged leg vice stand which had a small table.Alan Edited August 26, 2015 by Alan Evans Added photo of classic cast stand Quote Link to comment Share on other sites More sharing options...
FoxFire Posted August 27, 2015 Share Posted August 27, 2015 I'm betting that the mount is or was an after market item because I have the same type of mount on one of my vises and my vise doesn't look like yours. Quote Link to comment Share on other sites More sharing options...
FoxFire Posted August 27, 2015 Share Posted August 27, 2015 I think the swivel feature could be handy if the vise was mounted on the corner of the bench. In my mind (at least) it seems like it could be handy... Quote Link to comment Share on other sites More sharing options...
gote Posted August 28, 2015 Author Share Posted August 28, 2015 Hi Fox Fire, It could be an after market change but it looks contemporary. It can turn 90 degrees both ways when mounted the way I have it. I note that you also are in Europe. I will check what kind of threads are used. If they are Withworth it might indicate an import from the UK.Göte Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted August 28, 2015 Share Posted August 28, 2015 The shouldered hinge and the spring bolted to the moving jaw look quite different to the standard format.In combination with the swivel, the straight thread box and the heavy anvil protrusion from the back of the fixed jaw, makes me think it was like that from the outset.Somebody rethinking the whole thing.Alan Quote Link to comment Share on other sites More sharing options...
FoxFire Posted August 28, 2015 Share Posted August 28, 2015 Hi Fox Fire, It could be an after market change but it looks contemporary. It can turn 90 degrees both ways when mounted the way I have it. I note that you also are in Europe. I will check what kind of threads are used. If they are Withworth it might indicate an import from the UK.Göte Wrong Southampton, I live in New Jersey, USA. Here, is the link to my thread, http://www.iforgeiron.com/topic/41761-an-interesting-mount-clamp/ Quote Link to comment Share on other sites More sharing options...
gote Posted August 29, 2015 Author Share Posted August 29, 2015 (edited) Wrong Southampton, I live in New Jersey, USA. Here, is the link to my thread, http://www.iforgeiron.com/topic/41761-an-interesting-mount-clamp/OOPS I have read somewhere that the shouldered hinge is a feature of German vises. The other differences could point to it being of "Teutonic" decent rather than Anglo-saxon. Anyway I am happy to have it. Here in Sweden there are ten anvils for sale for each post vise - and not that many anvils at all. The svivel is different from your in that the bench side is thick enough to allow for the locking screw.Göte Edited August 29, 2015 by gote Quote Link to comment Share on other sites More sharing options...
Timlund Posted November 22, 2019 Share Posted November 22, 2019 On 8/25/2015 at 8:07 AM, gote said: All post vises i have sen in Sweden have been fixed this way and I find it practical to be able to put any tool I need on the bench. It is a swedish vise. Soderfors. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 22, 2019 Share Posted November 22, 2019 Welcome to IFI Timlund... Have you read this yet? READ THIS FIRST You might want to edit your post and trim down the quote and delete the pictures. We have many members who have to rely on dial up internet or pay for extra data and pictures are data hogs and take forever to load. Quote Link to comment Share on other sites More sharing options...
