Blower choice for ribbon burner
78sharpshooter
The flow rates are given at a range of discharge pressures and I'm fairly sure the value of 148 CFM is against 0.500" water column of Static Pressure.
Basically, it will develop something over 1/10th of the pressure you have read would be sufficient. Probably not a lot over.
If 12v is important try a mattress, rubber boat, etc. inflater. they put out a good amount of air at enough pressure to make a 6 man raft tight and you see them at garage/yard/etc. sales for a couple bucks all the time.
