Borntoolate Posted May 4, 2015 Share Posted May 4, 2015 Has anyone ever forged sensitized 347 stainless? If so is this an issue or not? I think this is primarily a polythionic acid issue but I am not sure...??? And if you are aware it is an issue is there a heat treat that may solve this problem such as a stabilize or solution anneal? Just looking for someone with practical hands on experience with this material in a sensitized condition... Maybe it will just crumble if not handled correctly...???? I kinda doubt it but if no one here knows for sure I will be finding out in the coming days/weeks.... Prior to that it would be good to start out with others learning and experience prior to my experimenting.... Before you ask how I know it is sensitized you can either just take it for granted (my preference) or... Because I know it has been in ~1000F service for many years and that we also have metalography of similar service 347 material that shows clear sensitization as determine by a metalurgist. This is potentially a heat treat question depending on the answer? But it may be a non issue so I placed it in general discussion. Link to comment Share on other sites More sharing options...
patrick Posted May 5, 2015 Share Posted May 5, 2015 Sensitized vs. non-senstized will make no difference during forging. This has to do with corrosion resistance. The sensitized condition is not as corrosion resistant as non-sensitized material. Maximum corrosion resistance is typically achieved in this and most other austentic grades by heating to 1900 F or higher and rapidly cooling to prevent chrome from reacting with carbon. T-347 and T-321 are stabalized versions in which either titanium or niobium is added to grab carbon before the chrome has a chance to reacte with it. If chrom combines with carbon, you get a reduction in the corrosion resistance. But at forging temperatures none of this matters since carbon will be dissoved in the austenite.You should be able to completely restore maximum corrosion resistance after forging by solution annealing. The nice thing about T-347 and T-321 is that they are less suseceptible to sensitization than are the regular austenitcs. This make them easier to fabricate, since often welded structures can't be solution annealed.Patrick Nowak (Metallurgist at Scot Forge for the past 12 years) Link to comment Share on other sites More sharing options...
ianinsa Posted May 5, 2015 Share Posted May 5, 2015 I kinda doubt it but if no one here knows for sure I will be finding out in the coming days/weeks.... Oh Ye of little faith! Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted May 5, 2015 Share Posted May 5, 2015 One of the many wonders of this little forum....ask a question and one is likely to have an real expert answere you! (This said compleatly with out sarcasm, a rair and dificult thing for me) Link to comment Share on other sites More sharing options...
Borntoolate Posted May 5, 2015 Author Share Posted May 5, 2015 Thanks All. I should have had more confidence! Link to comment Share on other sites More sharing options...
Please sign in to comment
