Welding Cart Project
My second welding project - getting better at it but plenty of room for improvement! This project was a Welding Cart to keep everything organized - this project is so me (I have a weird need to keep things in order - OCD I guess)! Will finish it with a coat of paint when it isn't 10 degrees out. It keeps my welder and plasma cutter "mobile" and everything I need all in one place. One less idea just banging around in my head now - hopefully it gives you an idea of something similiar you may find helpful.
BTW - it was all scrap yard finds.
post-56984-0-70986500-1423246297_thumb.j
post-56984-0-05221700-1423246311_thumb.j
post-56984-0-78550000-1423246332_thumb.j
post-56984-0-43739600-1423246346_thumb.j
post-56984-0-72011400-1423246363_thumb.j
post-56984-0-98164900-1423246379_thumb.j
post-56984-0-08508500-1423246395_thumb.j
post-56984-0-20402100-1423246409_thumb.j
post-56984-0-51086700-1423246425_thumb.j
post-56984-0-91263400-1423246445_thumb.j
post-56984-0-07735700-1423246461_thumb.j
post-56984-0-66000500-1423246485_thumb.j
post-56984-0-34827700-1423246499_thumb.j
Nice job.  I am sure you will be adding more "accessories" to it as the need arises.
That is really nice, I like the way that looks.
I might have to copy a few things about your idea.
Nice cart Robbie. Well thought out and the construction looks good.
I find having the cables rolled and laid flat tends to collect . . .stuff and tangles. Being able to hang them like a garden hose on the side of the cart works best for me so far. I have an old 12" +/- (scrounged) rim, cut in half welded to the side of mine to hang the cables. It keeps the ground and stinger organized. What works for me doesn't necessarily apply to your unit, I have 25' of ground and 30' of hot with a 15' stinger and all but the stinger is ought. I'm running a gs powered Lincoln ranger 9 gen set. There is a scale difference but some rules of thumb scale nicely.
I have wheel barrow tires and 3" swivel casters under mine and the casters aren't big enough. I think the casters under yours need to be larger or every little pebble will hang them up. Even on a concrete floor unless you sweep in front of it when you move.
Those are just my thoughts, I tweak everything. What you've done looks like it'll work beautifully.
