EricJergensen Posted November 7, 2014 Share Posted November 7, 2014 This is actually a rowing machine with pneumatic resistance. The weld failed. I'm concerned that it wouldn't be safe for me / the cylinder to weld it. In any case, I only have a stick welder not a spot welder. Repair suggestions? Quote Link to comment Share on other sites More sharing options...
KRS Posted November 7, 2014 Share Posted November 7, 2014 make sure the contact area is clean and put a thin rubber in the clamp. however you fix it, do both sides while you are at it Quote Link to comment Share on other sites More sharing options...
Ironmike Posted November 9, 2014 Share Posted November 9, 2014 You can't put any heat on that or it could blow up in your face! It was welded when it was a bare empty open cylinder and safe to weld Ironmike Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted November 9, 2014 Share Posted November 9, 2014 Sorce the appropriat automotive shock. The valving is very similar and will be built much better. Heavy vehicles such as 1 ton vans and trucks will offer more resistance wile shocks from a Pinto will offer less. Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted November 9, 2014 Share Posted November 9, 2014 Try some JB weld or some really strong glue for metal. They are surprisingly strong. Good luck Quote Link to comment Share on other sites More sharing options...
