November 1, 201411 yr Getting by with a track anvil can be difficult sometimes. I have already created a horn on mine, but getting a hardy hole has been a challenge. I believe having this hole would be a great benefit because you can place different tools in one to achieve different things. I have had a different piece of railroad track, not the track, but a different section that holds the rail timbers. In the video see how I ended up crafting a hardy hole section to hopefully achieve this. link removed Area under the track plate hole has been drilled out, Spike can now be modified to fit into the *hardie hole* and be used.
November 1, 201411 yr first I would have put it to the outside for better access to the tool. An other option is to get a block of steel and drill a hole in it file square and add legs
November 1, 201411 yr Author @Francis- I had thought about putting it on the outside, but was worried about the log splitting from impacts or anything. I can always go back and drill a hole there and then chisel out the waste. Thanks for the second idea for the block of steel.
November 1, 201411 yr is it okay to make your hardy tools using your anvil or should one use a swage block or a striking anvil
November 2, 201411 yr is it okay to make ypur hardy tools using your anvil or should one use a swage block or a striking anvil If you are forming the tools at a proper forging heat, use the anvil to create what you need. That is what the anvil is for. Use a swage block if you need to form curves in the top part of the tools. Using the square holes in a swage block can also be used the refine the corners when upsetting the top part.
November 2, 201411 yr Your anvil is too low. Your back will appreciate you raising it up to the proper working height. Get a piece of square tubing and place it in a bucket of concrete or otherwise secure it to the ground. Instant hardie hole.
