jukejoint Posted October 13, 2014 Share Posted October 13, 2014 Narrowed it down to two fans the first fan is a Kayne and Sons blower fan it sells for 175.00 the second one iam thinking on is the Dayton 2c647 that Centaur sells for 89.00 ,like yalls input on these two choices just want to make my forge right the first time .and not have to upgrade later thanks Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted October 14, 2014 Share Posted October 14, 2014 Forge, Burner, Fan, Flue, Location, Other Tools. They have to match. Which one are you taking about? The Chicken or the Egg? :unsure: :unsure: Quote Link to comment Share on other sites More sharing options...
jukejoint Posted October 14, 2014 Author Share Posted October 14, 2014 will be using coke, my bowl is the Vulcan model and elbow are from Centaur the fan should be no more then 3 feet from elbow 2 in inlet on elbow I think Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 14, 2014 Share Posted October 14, 2014 Fire does not care where the air comes from, just that it gets enough air to get the fuel burning and hot. ----------------------------- Blower 1 $175.00 164 cfm coal or coke forge blower - 40 oz. static pressure, 110 vac, 165 watt, 1.5 amp, 1/4 hp outlet OD approx. 3-7/8". - 4" pipe fits very nicely over the flange of these ---------------------------- ---------------------------- Blower 2 $89. I found this blower number as low as $61.44 Dayton Model 2C647 Blower 134 CFM 1500 RPM 115 Volts 60/50hz Wheel Diameter 5 1/4 Inches, Wheel Width 2 1/2 Inches, Inlet Diameter 4 1/2 Inches. Not recommended for speed control. Item Shaded Pole Blower (Another seller, same part number, additional specs.) Wheel Dia. (In.) 5-1/4 Wheel Width (In.) 2-1/2 CFM @ 0.000-In. SP 134 CFM @ 0.100-In. SP 126 CFM @ 0.200-In. SP 117 CFM @ 0.300-In. SP 107 CFM @ 0.400-In. SP 96 CFM @ 0.500-In. SP 79 Voltage 115 Hz 60/50 Phase 1 Full Load Amps 0.74 RPM 1500 Bearing Type Sleeve Motor Type Shaded Pole Motor Enclosure Open Dripproof Thermal Protection Auto Lead Length (In.) 21 Conduit Box No Ambient Temp. (Deg. F) 104 Max. Inlet Temp. (Deg. F) 104 Inlet Dia. (In.) 4-1/2 Outlet Height (In.) 3-1/8 Outlet Width (In.) 3 Overall Height (In.) 8 Overall Width (In.) 5-5/16 Overall Depth (In.) 7-7/16 Wheel Type Forward Curve Drive Type Direct Mounting All Position Housing Finish Gray Baked Enamel Housing Material Steel Agency Compliance UL Component Recognized, CSA Certified UNSPSC 40101601 Weight 4.400000 Description Shaded Pole Blower, Air Flow @ 0.000 Inch Static Pressure 134 CFM, Speed 1500 , Voltage Rating 115 Volts, Current Rating 0.74 Amp, Frequency 60/50 Hertz, Thermal Protection Auto, Wheel Diameter 5 1/4 Inches, Wheel Width 2 1/2 Inches, Inlet Diameter 4 1/2 Inches, Air Flow @ 0.100 Inch Static Pressure 126 CFM Restrictions Note: Not for use with speed controllers. 30 to 312 CFM PSC, Shaded Pole, DC, and 3-Phase Blowers, Rectangular Outlet Dynamically balanced blowers provide smooth and quiet operation. Noise and vibration are held to a minimum to maintain CFM at higher static pressures. Motors have cast-aluminum end shields for greater heat dissipation and protection, resulting in less downtime and longer service life. UL and C-UL Recognized (E47479), except 2C646 is not UL or C-UL Recognized, and 2C647 is UL Recognized (E22286) and CSA Certified (LR12645). Direct replacements for many OEM blowers with same physical footprint All-position mounting Min./max. operating temp. range: -20 to 104 F Max. inlet and ambient temp.: 104 F Motor enclosure: open --------------------------- The internet has information on many things. You sometimes have to look beyond the first hit to find the answer you seek. You also need to decipher and understand the answers you find. Rephrase the question, and get a better answer. (Which air supply will work on your forge) Answer (Many will work). Depending on your forge, how large a fire you want, how much heat you want, and many other factors. You heating 1/4 inch stock or 4 inch stock, using coal, coke, charcoal and etc. Which of the two blowers you have listed is best for you? That is up to you to decide. Quote Link to comment Share on other sites More sharing options...
jukejoint Posted October 18, 2014 Author Share Posted October 18, 2014 Well went with the Dayton 2C647A blower motor easy install and if it didn't do what I wanted I wasn't out a arm and a leg (like I was trying to find a vintage electric blower),works great will need a air gate if not you could burn up a lot of coke, heated 1 in bar in no time tried to control the air flow by placing a cover over the intake side but didn't take it down much, unless your using a hand crank safe to assume you need a air gate thanks for the help folks time to heat sum iron Quote Link to comment Share on other sites More sharing options...
