July 3, 201412 yr Have you considered making your own? That is one of the things still on my to do list. Robert
July 3, 201412 yr Thats one I've looked for a while back. No linen! Found white paper micarta at Jantz. If you fine linen, pls post!
July 3, 201412 yr USAKnifeMaker seems to have several returns on linen micarta for knife scales, looked to be in stock as well. http://usaknifemaker.com/catalogsearch/result/?cat=0&q=linen there is a 'bone' color that's probably a little too yellow to qualify as ivory, and they have a 'bleached melamine' linen micarta which is stark white, but IDK if that's the right product.
July 3, 201412 yr Author I remember years ago using Melamine for counter tops and quit using it because of cracking problems with the edges. Since knife handles are almost entirely edges that is out. But thanks for trying, appreciate it. I don't care for the [non] pattern in the paper micarta and want the white or ivory linen. Guess I won't be using any white... Dave
July 3, 201412 yr I opened a catalog for a place listed in the knifemaking section under supplers and they list ivory.
July 4, 201412 yr Author Rich, I checked all my sources and none list white 1/8 linen micarta in white or ivory. I had checked the suppliers list as well. I also went back to the list after your post. I still don't see any of the material I am looking for. Dave
July 4, 201412 yr I'm with the *make yer own* school. Its easy and you get what you want :) However if DIY just isn't in your wheelhouse, Chinobi nailed it: I went one click further and found Linen - Bleached Linen Melamine 1/8" Might need to update your source list ;) Edit: To be fair, US Knife Maker Supply isn't listed in the "Handle material" list but it is in the >Supplier list thread , From there its just a click or 3 or an appropriate search keyword away. Your mileage may vary :D Scott
July 6, 201412 yr Check out Bingham.com bow supply look under riser material they have white linen in several sizes and thicknesses
July 6, 201412 yr Is this the link you meant me miller?http://www.binghamprojects.com/products.php?cat=45
July 9, 201412 yr Yes that is the one. I don't really like the tan but the white,black, and red are good material.
July 9, 201412 yr Author I ordered some of the linen from the bow place. Will post again after it gerts here and I have a chance to try it out. Thanks to all for the suggestions :) Dave
July 11, 201412 yr Several years ago i wanted some red in wider strips. I had to wait until they got a whole sheet in but they cut me 4 by 39 inch strips so i could cut across instead of toward the end. i think they charged me $30 some dollars a strip. i thought it was a bargain.
July 21, 201411 yr Author Ordered from the bow place, it came and looks good. Haven't used any yet- probably not for a few days. Will post a pic and more info when I do. Dave
July 21, 201411 yr In the knfemaking lessons there is a place for any of us to list suppliers,...Did you add that to the list?
September 19, 201411 yr Author I actually used some and did a couple handles. That will be dry and ready to work tomorrow or the next day. I will get some finished pics up when they are available. I think I am happy with it but will follow through.Dave
