natkova Posted February 27, 2014 Share Posted February 27, 2014 Look at this fan it's impressive to me. So if you want to convert it to hand crank blower you could make these blade radial instead axial but it works good. Might this can work on foot like treadle lathe. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 27, 2014 Author Share Posted February 27, 2014 Here is another from this guy Quote Link to comment Share on other sites More sharing options...
Rashelle Posted February 28, 2014 Share Posted February 28, 2014 That is just too cute. My brain is spinning with ideas. Much like the fan blades now. I liked it. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted March 1, 2014 Share Posted March 1, 2014 Neat bit of work. No reason you couldn't adapt that with better gearing and a flywheel/treadle system to make a great forge blower. Quote Link to comment Share on other sites More sharing options...
natkova Posted March 1, 2014 Author Share Posted March 1, 2014 Only hard part is to make gears. They need to have same teeth i guess same dimension same pass it need a lot's of counting. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted March 1, 2014 Share Posted March 1, 2014 Making gears actually isn't that difficult when you're making them out of wood. There are some great tutorials on the net about it. Or, you could simplify it and just use belts and pulleys. One bicycle wheel with a bit of string wrapping around it and the small pulley on the fan shaft would give you some serious wind. Quote Link to comment Share on other sites More sharing options...
natkova Posted March 5, 2014 Author Share Posted March 5, 2014 Making gears actually isn't that difficult when you're making them out of wood. There are some great tutorials on the net about it. Or, you could simplify it and just use belts and pulleys. One bicycle wheel with a bit of string wrapping around it and the small pulley on the fan shaft would give you some serious wind. I think to make gears you need band saw. Quote Link to comment Share on other sites More sharing options...
Nobody Special Posted March 5, 2014 Share Posted March 5, 2014 If you make gears out of wood, it's easier if you cheat and download a pattern. Of course......to me, a wooden gear looks awfully like a pattern for an aluminum casting........hmmmm :D Quote Link to comment Share on other sites More sharing options...
jeremy k Posted March 5, 2014 Share Posted March 5, 2014 I think to make gears you need band saw.Yes a hand saw and file. Quote Link to comment Share on other sites More sharing options...
natkova Posted March 5, 2014 Author Share Posted March 5, 2014 The blower in pattern look good only transwer this to metal would be nice. Quote Link to comment Share on other sites More sharing options...
