Mildest steel
Hello all
New hobby novice blacksmith here.
Just got my forge setup and i am looking for some mild steel to use.
I have been to the local scrapyard and found some springs, but im trying to get mild steel.
I live in Europe (Norway) and i struggle to find mild steel.
My local supplier can provide me with S235 and C16 steel, i do not know what is the difference and is ? Is there milder steel than this i can ask for ?
Regards
Elefanten
Do you need to pay a steep premium for excessively mild steel?
C16
C 0.12-0.18
≤ Si 0.40
≤ Mn 0.60-0.90
≤ P 0.045
≤ S 0.045
S235
C 0.17
≤ Mn 1.40
≤ P 0.045
≤ S 0.045
Most of use are forging A36 these days when we want "mild steel" as it's the cheapest and easiest to find
C 0.25 - 0.290 %,
Cu 0.20 %
Fe 98.0 %
Mn 1.03 %
P  0.040 %
Si 0.280 %
S  0.050 %
Welcome aboard Elefanten, glad to have you. If you'll put your general location in the header you might be surprised how many of the IFI gang live within visiting distance. Town/city and country are generally plenty close enough.
I'm not much help with the mild steel but the guys have you pretty well covered. It's what we do, we help each other. Even if it's just a good laugh sometimes. <grin>
Hi and welcome Elefanten!
If you dig for scrap, look for longer, almost or totally straight pieces.  Round, rectangular or flat, every single one is mostly mild steel. If you can bend a meter long piece with your bare hands and then straighten it back - you found mild steel. (Except if you try to bend thicker stuff, or you are Thor in diisguise and able to bend springsteel, too.  :) )
Easiest to recognize the rebars (structural steel for concrete constructions = that iron stuff which sticks out from demolished concrete stuff), although it can be a bit unbalanced to work with - it may contain bigger amounts of carbon as mild steel.
I often try to check the sound of the material I found, doesn't work always, but gives some guidelines. Blunt ding (dung :) ) usually goes for mild steel, sharp ringing means high carbon. (Mostly, but...)
If you have a file with you, try and use it on the stuff: mild is cut by it easily, high carbon not quite. In time you can even see the difference between the filed-off metal dust.
Experiment with different materials - and keep looking around here, because the answers are already waiting for you, just have to find them.
Greetings and beste ønsker!
Gergely
Thanks all for the warm welcome !
This really helped me out, I can't tell if i get good prices from my local supplier but it gets me started.
Can you notice the difference in Manganese levels in C16 and S235 when forging ?
Gregerly : I will bring my new visdom next time i go to the scrapyard .
Stefflus : I am located in Rogaland County - Bryne.
Thanks again.
Elefanten
I don't usually notice Mn level variations much when hot forging though they do make a difference in cold working steel.
Try asking for the cheapest metal they have that is not concrete reinforcing rod.  I also ask for off size and damaged steel---rusty pitted marked, etc as I'm going to be changing the size and surface with fire and hammer anyway!
My last visit to the steelyard I bought 4 barrels of the heavy 1/4"-5/16" steel wire they use to bind steel bundles for shipping over here.  It's real soft under the hammer and there are lots of things I can forge from it and they sold it to me for SCRAP RATE!
