First Try at San Mai
schwatk
Hello All,
I’m new to bladesmithing.    I’ve successfully done a little forge welding of 1084 and 15N20.
I would like to try doing a San Mai or Laminate of wrought iron with a core of 1084.  If successful I’d like to make a skinner about 7 to 8 inches long and 3/16 thick.  The question I have is what thicknesses should my wrought iron and 1084 be, before welding?  Do I make the billet thicker and then forge it to a thickness of 3/16?  Also should I heat treat the blade like it’s just a 1084 blade?
As always Thank You for any and all help and recommendations.
Joe
Yes you want your billet larger so you can remove any mistakes; but not overly large as the WI will forge more easily than the 1084.
Now if you were welding with a powerhammer or press you might get away with setting the stop blocks a hair thicker than your end size for the last go.
