September 24, 200718 yr Hi there. I thought I'd post something I made for my workshop a while back, which has proved to be an extremely handy addition. I don't have a lot of room in my shed, and was having trouble mounting 2 bench grinders. Simply can't fit them side-by-side, and originally made a trundle bench with them back-to-back. It always seemed to be the one at the back I wanted to use which really started to wick me off, so I designed to following setup. The guts of it is the "L" shaped bed which pivots through 90* back and forwards, and has a positive lock at each extreme using a cam handle. The pivot is a 1" shaft running in brass bushings, very solid with no play. Quite straight fwd to use, by grasping the bed with one hand, unlatch the handles and tilt either way to expose the applicable grinder, then relock. It has no tendency to vibrate loose, really quite solid. The only trick was to cable tie the leads to stop them getting pinched. At present there is no assisted lift, but I guess as I get older I might install springs, gas strut or counterweight! In that space at the bottom between the legs I have fitted a large metal drawer to stash buffer wheels and belts, rouge etc. Hope you enjoy the pics, which are of the down & locked position, the halfway and the fully up. Makoz
September 24, 200718 yr thats great, how about you make one for me and ill try it out and send you a good product review, haha i think i may make something like that myself, space is pretty limited for me to
September 24, 200718 yr Cool. It looks like you even have room to add some storage for extra wheels, buffing supplies, etc. I'd like to add another grinder eventually, and that's not an option I had considered. That would be a good way to keep a wire wheel set up and out of the way.
September 25, 200718 yr Author Thanks for the compliments! It was one of those jobs which it seemed like a good idea at the time, but no proof until the last minute, when both grinders where fitted! Cheers, Makoz
September 27, 200718 yr Makoz, That is a fine idea. I just happen to be looking for ways to use my shop space more effectively. Please consider the concept stolen. Thank You for sharing your project, that is what IFI is all about! Be safe! Old Rusty Ted
