Honor blade project WIP
Geoff Keyes
Just an update on my progress.  I had to re-do the HT because the blade took a kink.  I normalized a couple of times and the second try came out straight.
post-46125-0-13387200-1378777509_thumb.j
Ground at 36 grit and ready to go
post-46125-0-96612200-1378777551_thumb.j
post-46125-0-05080200-1378777569_thumb.j
post-46125-0-87678700-1378777588_thumb.j
Stable at 1550 F
post-46125-0-08202300-1378777680_thumb.j
Ready to grind
post-46125-0-88857800-1378777720_thumb.j
I ground to nearly sharp and finished up with a Gator belt.   The rest of the day I spent hand sanding to a clean 220 surface.  It goes a lot fast from here on out, 10 or 15 minutes a side per grit to 1500.
Thanks for looking,
Geoff
Not too pretty, but it does the job.
So here we are, my last post for this one.  After consulting with one of my fellow craftsmen on this, I etched and polished to 1500 grit.  This did expose a couple of weld flaws, but I don't think they'll distract from the finished product too much.
post-46125-0-85152100-1378936817_thumb.j
post-46125-0-54917700-1378936835_thumb.j
So now this is off to the next guy on the list, and he'll be continuing this thread.
Thanks for looking in
Geoff
There is a small weld line right in the tip, on the non presentation side.  It's probably my fault, and if it had been my project, I'd have shortened the tip just enough to get rid of it.  Otherwise it's all tight.  BTW, The pattern on the presentation side is much more active than the other side, though they are both pretty cool.
Geoff
  • 1 month later...
Posted · Hidden by Steve Sells, October 29, 2013 - sending off site
Here is the Up date to this project it is moving along very well I will start my part very soon as I just returned Home from a 20 day Vacation .
http://www.bladesmithsforum.com/index.php?s=e481d1bdcb4da8642c7aaf8001a3f491&showtopic=27339&hl=%20honor%20%20project
Sorry for the link to another site However some of the folks are not on this site to post their part of their work here .
Sam
  • 4 weeks later...
Ok Folks I should Be finished by the end of this week with my stage of this project . I would like to express my Deepest Apologizes to the other Smiths that worked very heard on this project , as I am No where near as fast as they are with their work . I have to take my time and have had quite a few Bad days while trying to complete my part of this project . I will However Post my WIP photos / link to them or try to see if i remember how to do so on here LOL .
Thank you for your understanding with my slow progress .
Sam
