The Chukster Posted June 27, 2013 Share Posted June 27, 2013 Guys, I am trying to separate the ball caps on the handle of my Chas. Parker Model 434 1/2 vise and I am having some difficulty. I assumed these were screwed on, but now I am wondering if these darn things were forged on the ends of the rod handle. Any one else ever have trouble separating these ball caps on this model of vise before? I could use some help on this one. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 27, 2013 Share Posted June 27, 2013 I don't know about that particular brand but I have seen ball ends Forged on, brazed on, pinned on and even welded on. Screwed on is low on the list of ones I have seen. Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted June 27, 2013 Share Posted June 27, 2013 If I remember correctly mine were integral to the handle. I would assume that the balls were upset forged in some sort of press. If you have the machine with the dies this is the fastest way. Quote Link to comment Share on other sites More sharing options...
marcusb Posted June 28, 2013 Share Posted June 28, 2013 Why are you taking them off? Quote Link to comment Share on other sites More sharing options...
MLMartin Posted June 28, 2013 Share Posted June 28, 2013 I have a vice that has ball ends that are riveted onto a bar with tenon ends. I believe this specific vice has had the screw replaced by a machinist as a one off. Why do you need to remove the handle from the vice? Quote Link to comment Share on other sites More sharing options...
The Chukster Posted July 4, 2013 Author Share Posted July 4, 2013 I want to remove the ball caps because the handle is bent on a 15+ degree angle, and the ball caps don't look much better, I have a set of 1 1/2" brass balls from an old machine I was restoring that I thought would look good on a stainless shaft to replace the beat up one that is one the vise now.. Quote Link to comment Share on other sites More sharing options...
seldom (dick renker) Posted July 6, 2013 Share Posted July 6, 2013 if your going to replace the handle just use your smoke wrench. chances are the the balls are on there solid Quote Link to comment Share on other sites More sharing options...
