nogrodoth Posted May 23, 2013 Share Posted May 23, 2013 So I just finished my first forge and tried out smithing for the first time, might anyone be willing to critique my first attempt at tapering and drawing out? i was using the same 1" diameter bolt for all of this my forge square taper rounded taper drawning-out, I'm attempting to make a pair of tongs thanks:) Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted May 23, 2013 Share Posted May 23, 2013 Ok, critique time. You asked for it. Looks good to me! Keep on keeping on. Mark <>< Quote Link to comment Share on other sites More sharing options...
neg Posted May 23, 2013 Share Posted May 23, 2013 Looks like a taper alright... now turn it into something! :P Quote Link to comment Share on other sites More sharing options...
VaughnT Posted May 23, 2013 Share Posted May 23, 2013 Critique? Okay. The tapers are smooth and relatively free of hammer marks. The corners of your square appear sharp. The curl is a bit off because it looks like it collapsed on itself. This gives it more of an egg shape rather than a circle. Not bad, but not "artsy" either. Looks a bit wrong, but certainly a functional finial. Overall, I'd give it a very high rating. For your first attempts, getting that quality really says a lot about your potential. Smooth tapers, sharp corners and a lack of hammer marks..... that's excellent work. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 23, 2013 Share Posted May 23, 2013 Okay, you asked for it. <grin> An uniform smooth square taper from round found stock. Crisp edges, properly square, no visible rhombusing. That step gets'a a high passing grade in my class. Rounded nicely only a very little texture left, on a smooth uniform round taper, solid passing. Finial scroll egged a bit but another solid passing grade for first attempts WITHOUT an instructor kibitzing over your shoulder. For a your attempt at the anvil, Solo, I'd give you a solid A. If I were coaching on the scene it'd be a solid C+. You have an eye and knack for smithing, keep at it and we'll be asking you're advice in no time. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
nogrodoth Posted May 24, 2013 Author Share Posted May 24, 2013 Cool:) I hadn't really been paying much attention to the curl, I guess I should have:P it was the point of the round taper so I was just trying to get it out of the way and the half-of-a-tong-handle needs a good bit more work to make it exactly what I think would be good, as far as i can tell, but i'm happy I'm not doing too awful:P thanks:) Can't wait to get back to my forge:):) Quote Link to comment Share on other sites More sharing options...
Faber Posted June 8, 2013 Share Posted June 8, 2013 Great job, I actually just fired up my brake drum forge and did some work yesterday for the first time as well. It definitely feels great. Keep it up. Quote Link to comment Share on other sites More sharing options...
