Curing stove paint on open firebasket
Greenbeast
I'm currently building a fire basket for someone, it's my first.
I'm looking to paint it with black stove paint but apparently it is a bit soft and liable to scratching until cured (obviously it's intended for the outside of a wood stove.
any ideas?
or better suggestions?
Greetings ,
I never seen a fire basket that did'nt rust... I can assume you want it to look good for a while....  If you heat it up with a weed burner and put drain oil on it it will form a black carbon look...  Its stinky and will fire flash at about 900  Be carfull..  Do that a few times and it will blacken ..   ANNNND   it will still rust after a while..
Good luck
Jim
