wolfshieldrx Posted December 14, 2012 Share Posted December 14, 2012 I seem to remember reading somewhere that traditional English smiths would leave a couple of inches of the edge of the anvil just behind the table/horn unground. They would leave this area sharp and use it to hot-cut instead of using hand-held hot-cut or hardy tool. Has anyone else ever heard of this or seen examples? Or did I just dream it? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 14, 2012 Share Posted December 14, 2012 Don't know about "traditional English smiths" but I know a lot of smiths who have used an edge for cutting. Usually not right behind the table as that's generally close to the sweet spot and they wanted to be able to use that area without worrying about cold shuts. (Of course it could be that on the heel the edges tend to star sharper anyway and so they used what was there already) Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted December 14, 2012 Share Posted December 14, 2012 It's bad practice - use a hardy, that's what it's made for. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 14, 2012 Share Posted December 14, 2012 Sometimes it will give you the angle you need for your next operation. I tend to have slitting hardies rather than blunt ones. Quote Link to comment Share on other sites More sharing options...
tomhw Posted December 15, 2012 Share Posted December 15, 2012 Sometimes it will give you the angle you need for your next operation. I tend to have slitting hardies rather than blunt ones. Well said. Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted December 16, 2012 Share Posted December 16, 2012 I've usually seen the opposite done, that is to round the first inch or two where the horn meets the table. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted December 16, 2012 Share Posted December 16, 2012 I have tried using a shearing blow to cut small stock near the heel of my anvil, but over the body. A shearing blow is where the hammer is exactly off the anvil, and strikes the stock that is on the anvil. This parts the material. I have only been successful with real small stuff, 1/4 inch, if you find references to this in old texts they only recommend it for small stock, less than 1/2 inch. I use a hot cut because my hammer control is not always perfect and dressing a hardy is easy. I also fear damaging my anvil do to a mis-strike. I have also tried pinching the metal into a deep fuller in the same manner, but since my anvil does not have perfect edges the result is not very neat or quick. I use a hot cut because the results are better and quicker. As for dressing an anvil there is a nice FAQ on Anvilfire.com Phil Quote Link to comment Share on other sites More sharing options...
Dan P. Posted December 16, 2012 Share Posted December 16, 2012 English smiths are as different from each other as American smiths, or any other kind of smith. Do this if it makes sense to you, if not, don't. Personally, as an English smith, I do this from time to time, when accuracy is unimportant. Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted December 17, 2012 Author Share Posted December 17, 2012 Thanks guys. I never intended to do this, only asked if you knew of it being done. I am sure I remember reading something about this in reference to rural English smiths. I was trying to relocate that reference. Thanks again...bart Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 17, 2012 Share Posted December 17, 2012 I've used the anvil edge as a fuller with a straight or cross peen hammer to work an equal and opposite side fuller into a piece like the blade-tang transition for a knife. It does take precision hammering to get them matching. I find it much easier to use the swing arm fuller I built---but it's not always to hand at a demo. And as I *often* say: "There Is Only *ONE* Right Way To Do Blacksmithing; And That Is: ANY WAY THAT WORKS!" Quote Link to comment Share on other sites More sharing options...
