thanks steve!!!
Rhettbarnhart
Steve sells was kind enough to send royce and i a "care package" of steel and sanding belts :D here is what i came up with.....
steel is 1095(from steve)
oa length is 7.5 in
blade length is 3.5in
handle length is 4in
bolster and pins are brass
handle is stabilized burl(i forget what kind) i used dark walnut stain and linseed oil to finish it
enough talk now for pics
post-25948-0-26411100-1355279804_thumb.jpost-25948-0-92886600-1355279817_thumb.jpost-25948-0-51161600-1355279832_thumb.jpost-25948-0-48397000-1355279848_thumb.jpost-25948-0-07441400-1355279864_thumb.jpost-25948-0-40274200-1355279891_thumb.jpost-25948-0-46724000-1355279904_thumb.jpost-25948-0-15199800-1355279931_thumb.j
thanks for lookin
Ajax said.....looks great, one suggestion though. If it was me I would make the handle a little more round and more ergonomic. other than that its a nice knife
thanks i will remember that on the next one
steve sells said......
your welcome,
I see you have been coming along well. If you could make a smoother transition rather than the fast blunt change from side of blade to cutting edge. that is the only obvious thing I see. great work, and great result
from the man that started it.........thanks steve the grind starts about 1/4 in down from the spine but my grinding and filing skills arent that great and it is hard to see.....
bosox said....Wow! Outstanding.. :D
thanks dude :D
