schnor Posted November 30, 2012 Share Posted November 30, 2012 Just getting started in Blacksmithing I'am repairing a coal forge for my high school project. I need a new Tuyere Plate. Does it need to be cast iron or can it be made out of steel? It needs to be 6 inches in diameter. Does anybody know where i can buy one? Quote Link to comment Share on other sites More sharing options...
VaughnT Posted November 30, 2012 Share Posted November 30, 2012 There is a guy on ebay that sells "tuyere plates" for about $20. You can certainly make one of your own out of mild steel, though. All it takes is a bit of mild steel and a drill and/or mill. What type of coal forge do you have? Does it have a deep firepot made from cast iron, or is it a shallow dish with a flat plate tue? Quote Link to comment Share on other sites More sharing options...
schnor Posted November 30, 2012 Author Share Posted November 30, 2012 It is a deep firepot made from cast. Also should i put in a layer of high temp concrete? I can maybe post a picture later. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 30, 2012 Share Posted November 30, 2012 Nope the high temp concrete will just stick more clinker to it and it can be handy to be able to remove such a plate and clean any clinker off it with a hammer. Quote Link to comment Share on other sites More sharing options...
Private Entrance Posted November 30, 2012 Share Posted November 30, 2012 I used a piece of sheet metal from an old washing machine for mine. I don't expect it to hold up forever, but it works just fine for now. Be creative - my vote is that you can come up with something that will work great. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 30, 2012 Share Posted November 30, 2012 Actually for my tuyere I use diamond pattern expanded metal replacing it as needed. I find the scraps for free. I do have to take it out after a hard day of welding and hammer off the fluxcicles Quote Link to comment Share on other sites More sharing options...
RoosterretsooR Posted December 1, 2012 Share Posted December 1, 2012 I used a cast iron strainer from a floor drain...plumbing dept. in big box home improvement store. Rooster Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted December 1, 2012 Share Posted December 1, 2012 A photo or two would be helpful. Are you sure that the firepot you have is designed to have a tuyere plate? Quote Link to comment Share on other sites More sharing options...
