July 20, 200520 yr JPH; Kind sir. I have acquired some grainy(nice) WI. I have no experience with this material. I know that it has to be hot to shape. I wonder how to lay out and keep straight, while filing the grooves, in the ferrells that go behind the guard. I started a topic over on DON'S site and did not get much feed back. They did tell me how to etch it. Nitric at 5:1. Would you care to comment on this subject.GRIN.. Thanks Chuck Bennett
July 20, 200520 yr Chuck, W.I. needs to be FORGED hot , all your filework and grinding is done cold. Wrought iron is a pleasure to work, at the right temp it moves like soft butter under your hammer, just dont hit it in the black-red range as it will crumble. The stuff makes nice sword/ knife fittings(pommels and gaurds ) and is great for laminating with higher carbon steels to make wood working tools in the japanese style. As far as etching I like Cider vinnegar and sea salt, suspend the part over the mix for a few days, this works best when warm, this also works with damascus blades too , even produces a beautiful patina on copper. Hope this helps man. Jens
July 21, 200520 yr Author Oakwoodforge; Thanks for the info. I had not heard of etching like that.. I will have to give that a try. I will have to figure how to duplicate the seawater. GRIN I am 900 miles from the closest salt-water.BOG. I have messed with some lower grade WI. Made some hooks and hinges out of it. No etching. YUP!! I splintered the end of one. Will not let it get that cool again.GRIN. Thanks Chuck
July 21, 200520 yr Sea salt is a product that is sold for womens complexion. So only use it if you are making a womans knife :)
September 25, 200520 yr Or, you could look up the sea water salt to water ratio. I dont remember what it is, off hand.
September 25, 200520 yr low grade WI like wagon tires will literally explode if you hit it at too high a heat and cracks if worked at too low a heat, I use it for antique woodworking tool repairs, I just bring it up to an orange and work it under the power hammer a coupla times lightly. It destroys the grain and refines it so you can work it easily.
