Problem with candle spike
Hi, I have a problem with candle spikes ( sorry I don't know the name of that part, you'll see in the picture what I'm talking about).
How in the old days did they make this part, the small spike where the candle sits on. When there is a scroll under the pan, you can make a tenon and rivet it from under, but like in the picture, I don't see how without arc welding. If someone has a clue, I'm taking it because I want to make candelabras like this one and I don't want to tack it. My stick welder, even at the lowest amperage is too powerful and burns a hole in half a second in a pan of 16 ga steel.
post-9026-0-96415900-1339110748_thumb.jp
If I'm understanding your question right, it looks to me like they made the spike from the end of the arm the dishes sit on. The dishes look like they have a hole in them that lets the spike come through, and then the dishes look like the sit on top of an upset/bulge/collar on the arm.
That's what I see, anyway. Not that I know anything. I'm still a noob. ;)
Yes you understood right, but I wonder if the dish is solidely attached to the arm or just sitting loosely on it.
the dish is solidly attached the pointed part goes thru the pan then a rivet set that is a little smaller than the hole thru the pan is used to pien over a bit of the spike ... hard to describe an kinda hard to get right but it can be done... helps if you make a sholdier for the pan to rest on...
The spike IS the tenon, and the pan is a "washer". I say washer because the pan has a small hole that gets forced over the spike.
Phil
Ahhhh! Thank you very much guys for the explanations. The BP Larry, explains everything very well. Now I need to make this new tool. Thanks again.
John_zXz
Hi John, We know the "spikes" as prickets
One of the problems with modern candles is there wicks have washers on at the base of the candles when they are made, Prickets can hit these washers and crack the candle, so take care.
Hi John,
Thanks for the advise and for the name. I have one of those candle with a washer and worried a bit with them. I'll be careful.
You can also forge braze the pans onto the pricket, or if you are the type that likes that sort of thing you can end the shaft flat and drill and tap it and then forge the top of a bolt to the pricket and screw them together---shudder
