matto Posted May 16, 2012 Share Posted May 16, 2012 what hight should i have my canedy otto #10 post drill off the ground? ground to bottom bracket? as soon as i get my pics i will post. Quote Link to comment Share on other sites More sharing options...
ciladog Posted May 16, 2012 Share Posted May 16, 2012 Mount it at a height where it is comfortable for you to crank all day long! Or you could mount it near the ceiling and stand on a ladder or maybe near the floor and crank on your knees. :D Quote Link to comment Share on other sites More sharing options...
Gayle Brooks Posted May 16, 2012 Share Posted May 16, 2012 Mount it at a height where it is comfortable for you to crank all day long! Or you could mount it near the ceiling and stand on a ladder or maybe near the floor and crank on your knees. :D haha! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 16, 2012 Share Posted May 16, 2012 Too high is hard on the shoulder, too low is hard on the back. The "sweet spot" is specific to you and how your body is put together. May I suggest you take a chunk of 2x6 and mount that and then move the drill up and down along that until you decide it's just right and then bolt it in firm at the spot you want to have it. Quote Link to comment Share on other sites More sharing options...
dkunkler Posted May 16, 2012 Share Posted May 16, 2012 May I suggest you take a chunk of 2x6 and mount that and then move the drill up and down along that until you decide it's just right and then bolt it in firm at the spot you want to have it. Good idea Thomas. A good starting position would be with the crank handle in the topmost position, level the crank handle with the center of your shoulder joint. Your hand will be shoulder height at the top of the rotation. Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted May 16, 2012 Share Posted May 16, 2012 I remember reading somewhere (here?) that the crank handle should be at shoulder height at its highest point. Thats how I installed mine and it seems to work well that way. However, as one of the other posters pointed out, it may be a very personal subjective thing, so that height may need to be tweaked a bit. bart Quote Link to comment Share on other sites More sharing options...
matto Posted May 16, 2012 Author Share Posted May 16, 2012 thanks for the thoughts, i have a large screw house jack that i can set it on. to help move it up and down. i might try to rig a chain fall above where it will be mounted. i'm 140 lb, it is around 275 lb need all the help i can get to put it in place. Quote Link to comment Share on other sites More sharing options...
