Marklink Posted January 23, 2012 Share Posted January 23, 2012 Need some information about Flap Disk Quote Link to comment Share on other sites More sharing options...
jeremy k Posted January 23, 2012 Share Posted January 23, 2012 go to your local welding supplier Quote Link to comment Share on other sites More sharing options...
rthibeau Posted January 23, 2012 Share Posted January 23, 2012 I use them all the time. http://www.aaabrasives.com/products/coated_abrasives/flap_discs/flap_discs_high_density_t-29_phenolic_backing_tru_zirk_58-11ah_4-12-7 Quote Link to comment Share on other sites More sharing options...
Tom Allyn Posted January 24, 2012 Share Posted January 24, 2012 They don't cut as fast as coarse-grit sanding discs but they last longer and they grind and polish in one step. I keep some around. Quote Link to comment Share on other sites More sharing options...
John B Posted January 24, 2012 Share Posted January 24, 2012 They don't cut as fast as coarse-grit sanding discs but they last longer and they grind and polish in one step. I keep some around. That can depend on how you use them and what grade of grit the disc is. They come in various grades of grit from coarse through to fine Quote Link to comment Share on other sites More sharing options...
Tom Allyn Posted January 24, 2012 Share Posted January 24, 2012 I've never found them in 24 grit at my local supplier. OTOH, 24 grit sanding discs are always in stock. But I'll defer to you on the availability in the UK. Of that I have no knowledge. Quote Link to comment Share on other sites More sharing options...
rthibeau Posted January 25, 2012 Share Posted January 25, 2012 AAAbrasives carries them in grits of 36, 40, 60, 80, and 120. I generally use 60's and 80's. Quote Link to comment Share on other sites More sharing options...
Marklink Posted January 27, 2012 Author Share Posted January 27, 2012 Thanks for information guys. I found site, they provide top quality zirconia flap discs, surface conditioning abrasives and diamond blades and also compare it . (blog.benchmarkabrasives.com) Quote Link to comment Share on other sites More sharing options...
Spears Posted January 27, 2012 Share Posted January 27, 2012 I use the brand on the right and they work pretty well. Enco has them in their sale catalogue quite often for probably $4 maybe less. I think Dewalt may be a bit better disk but like anything else that's good it will usually cost more. Quote Link to comment Share on other sites More sharing options...
Old N Rusty Posted January 27, 2012 Share Posted January 27, 2012 The flap discs for the 4-1/2" grinder by WALTER are backed up with a plastic disk. When finishing welds by using the end of the flap disc, new edges can be made by holding the spinning wheel against a sharp steel edge like under the table corner and removing some of the plastic to expose new ends. These discs are saved just for this app.. The brand I use for all other apps., in various grades of grit , is PFERD. A long lasting wheel that is more balanced than many others( hand fatigue) and the well is deep enough that wheels without the nut ( cheaper) fit without the round nut or spindle touching the work. I have bought NORTON wheels, both flap and hard, with the nut crossthreaded and cannot be used, OR tapped so oversize that it will not tighten or stay on the grinder. I like to use flap discs for just about everything, and got boxes of worn wheels kept forJustin Case. Can't bring myself to throw them away. Not to hijack this thread, but how many of you use the 4-1/2 " thin cutoff wheels? RAZORBLADE is one brand name .They are 1/16" thick and really cut fast, both steel and flesh.I use them a lot while fitting work in a jig for those long angled cuts, that only can be done with a torch or these wheels. Quote Link to comment Share on other sites More sharing options...
