Anvils
I've worked a few PW's myself and I like them, but considering they are English I might be biased! :D
Kholswa are good as well, as are Sodofors, Bofors, Mousehole, Trentons and many others. As long as it 'feels' good to you, it's good enough. Russian anvils are better used as door stops, although recently someone said after re heat treating theirs it actually wasn't that bad.
Use it daily, no rust. If you put a light coating of ATF (Automatic Transmission Fluid) on the face of the anvil it keeps the rust down. ATF does not get on the hot steel the next time you use the anvil like some other things that have been recommended.
