karine Posted December 1, 2011 Share Posted December 1, 2011 Okay, I'm cutting aluminum all day & I'm supposed to start welding pieces together tomorrow. Time to get new respirator(s) ! Pronto! No more fooling around. Already went to Lowe's & they don't sell "boo" for filters I'll need. Time to hit the catalogs for my "make due" solution (masks under masks) until I can find a more permanent one. RRRgh! What are you guys wearing when you have to work in aluminum &/or stainless steel. Advice ??? Quote Link to comment Share on other sites More sharing options...
clinton Posted December 1, 2011 Share Posted December 1, 2011 I use the 3-m respirator when I am welding (usually galvanised metal or structural steel) On stainless I do not use anything as there is very little smoke created (yes there are fumes) not good for you. http://www.ramweldingsupply.com/products-view.mcic?s=5134 Quote Link to comment Share on other sites More sharing options...
Thomas Dean Posted December 1, 2011 Share Posted December 1, 2011 Fumes from either alum or stainless are not a problem IF you are welding in the TIG process. Stick welding Stainless is where you get into the Hexv.-chrome problems and there is a whole list of stuff that OSHA requires. We no longer weld stainles using SMAW, only GTAW. (We are a Fortune 500 chemical company) Like Clinton mentioned, the 3M products are good and easy to find, most welding supplies will have something in store or can order for you. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted December 1, 2011 Share Posted December 1, 2011 Call up our local welding and gas supplier, they may have what you want in stock. Remember that fume removal is another consideration, and will improve your air quality. Phil Quote Link to comment Share on other sites More sharing options...
Larry H Posted December 2, 2011 Share Posted December 2, 2011 awisco welding supplies has a nice shield with forced air for under $500, light weight too Quote Link to comment Share on other sites More sharing options...
John McPherson Posted December 3, 2011 Share Posted December 3, 2011 Can't get a picture to load. 3M (and others) make low profile half-face respirators that will fit under a welding mask. Any good welding supplier should carry them. The rule for metal welding fumes is: "if it don't rust, don't trust." Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted December 3, 2011 Share Posted December 3, 2011 Here is the publication by 3M on their website to help folks decide which mask and filters fit their needs. The pamphlet describes for welding that they recommend the choice to be either a reusable mask of the 3M 7500 series, or a choice of two disposable masks. Four filters for the reusable masks are described in the pamphlet. Based upon the reviews that I read, I have ordered a 3M 7503 mask (the 3 standing for large size) and the 2097,P100 filters. I found the mask on Amazon for $22.79 and a pair of filters for $6.98 with free shipping. Based upon my experience with older 3M masks/filter combinations, the masks sold by 3M for welding just seem to keep getting better.http://solutions.3m....ibute=ImageFile Just my opinion, mileage may vary. Quote Link to comment Share on other sites More sharing options...
Backwoods Blacksmith Posted December 3, 2011 Share Posted December 3, 2011 Why do you think you need a resperator? Are you working in a closet?. Any space with cross flow ventilation will supply enough flow. If not, use a small fan to pull in fresh air. Tig welding is the cleanest of all open air welding. Keep about 15 to 20 CFM argon flow and keep the breeze off your puddle and no resperator is necessary. Read your msds that comes with your rod or ask for one at the weld supply. I have spent hrs welding using a resperator and I would not wish that on anyone. Stick welding stainless is a whole different ball game where air filtration is a must. Quote Link to comment Share on other sites More sharing options...
meancoyote Posted December 5, 2011 Share Posted December 5, 2011 I use a NORTH welding respirator, it is cheap, works well and has replaceable filters. http://www.grainger.com/Grainger/NORTH-BY-HONEYWELL-Welding-Respirator-4RM12 Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted December 7, 2011 Share Posted December 7, 2011 I was just at the local Lowes, and noticed that they now carry a 3M 6000 series respirator, as well as the 2097 P100 filters. Quote Link to comment Share on other sites More sharing options...
